Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftman garage opener
And yes its a blinking 5 times and pause...what had happen earlier was the door close a foot and open back up by itself then I increased the down force and works for like...10 min and problems resume again...the opener its about 4 years old...
  • motto_L Jun 22, 2009
    Thanks for the help...let me try to replace the sensor hope that will fix it and not the motor...
  • motto_L Jun 24, 2009
    fixed thanks!
    President:
  • 3,197 Answers
The blinking LED is sending the code for "RPM sensor or motor overload. It isn't the motor or it wouldn't run at all. The RPM sensor is a small printed circuit board near the front of the motor. It will be available at Sears or any good door opener service company.
Posted on Jun 22, 2009
My craftman garage opener will not close. The up arrow blinks 3 times and the down arrow blinks 2 times. the button on the unit will not open or close it. It will move about a foot then reverse back.
try holding in the wall button the whole time. if the door closes, then you have an issue with the sensor wiring. if the wall button closes the door while holding in, then post a comment below and we will tell you next steps.
Oct 02, 2015 | Building Materials
I have a model 139.53672srt1 garage door opener.Door opened fine but will not close from remote or wall switch, light goes on but door does not move or engage.
if you hold down the wall button will the door close? if yes, then the safety photo sensors are the issue==pretty common issue. either they are not aligned or one of the wires to then is lose or broken or shorted out(staples thru the insulation)
Jul 10, 2015 | Building Materials
I have a craftsman garage door opener model 139.53674SRT2. It was working fine and we opened it and closed it twice today with no problem. The third time we opened it, it would not close. Both led...
The led blinking 5 times is the code for "RPM sensor or motor overload." The motor has an thermal switch which opens when the motor get hot from running too much. This automatically resets itself after about 15 minutes. This problem can also be caused when the door opens too far and the trolley jams against the bolt just in front of the motor unit. To correct this you need to loosen the chain enough to eliminate the tension against the trolley and then run the motor until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opens fine but will not close unless I press down the button on the wall. The sensor lights are solid and I unplugged it for a minute and I'm still having the same problem.
If your main light flashes 10 times and the door reverses to the open position when you use your remote it is a door sensor problem. It is sometimes very hard to see if one of the sensor lights is flickering.
If the main light does not flash then you can try increasing the down force just a little. This control is on the rear of the motor unit near where all those white wires go.
Check the small LED near the smart/learn button. If it is flashing a code of 5 blinks then a pause and 5 blinks it is the RPM sensor. This is a small printed circuit board just in front of the motor.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close!
If the main light flashes 10 times when the door reverses it is a problem with the door sensors. Make sure the small light on each sensor is lit and not blinking ever so slightly. If it doesn't flash it is most likely the RPM sensor which is a small printed circuit board just in front of the motor. There is also a possibility that the down force needs to be increased. This is a control on the rear of the motor unit near where all those white wires go. Increase it about a quarter turn.
Sep 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsmen garage door won't open. 5 blinks and a pause on ind.
Most commonly this is caused by the trolley jamming against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door closes. On the side of the motor unit you will find a control labeled 'up limit'. Turn this about 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt. Should do it for you.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage opener opens back up when half way down
increase down force, especially if you are in a cold climate. turn to increase down force a little. test door to see if it reverses upon hitting something w/o too much force.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close in cold weather
find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Raynor 1245rgd navigator learn button blinks
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
235 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
