Question about LG WM1812C Front Load Washer
The washer has the bad smell, how do I take it apart to clean the filter?
  • 331 Answers
The smell maybe coming from the filter and filter cap assembly. www.techray1.com click on the guru guy and use the drop down menus to pick the parts needed. You may also check the drip pan for mold and debris kindly please rank me if this helped
Posted on Jun 22, 2009
My Kenwood PAC C130EK has a musty/damp smell when it's running; what could be the cause? I cleaned the filter and it ran smelling clean after that.
Mold in the washer is the cause of the odiferous smell, they make products to control this, I think TIDE makes it as well as others. Bleach kills mold as well.
Jun 22, 2017 | Dryers
Amana washer smell
You have mildew in the machine, best way to prevent it is to keep the door cracked open when not in use. Only way to remedy current problem that I have found works for sure is physically taking the machine apart and disassembling the drum and cleaning it by hand. I had to do my frontloader like that.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 16, 2018 | Washing Machines
Washer smell
If this is a front loader, clean around the rubber "boot" inside the doorway between the front of machine and the drum by pulling out a little to reveal buildup behind it. This can get a funky smell. You can also run the "sanitary" cycle if your unit has one, with bleach, which will clean the tub better.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jan_ed8272c8c2968d14
Jan 12, 2012 | Kenmore Washing Machines
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Inside of washer smells bad!!
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Apr 28, 2010 | Amana NTW4500V Washer
It makes my clothes smell really bad
I am not familar with this machine...but
it probably has a lint filter on the washer somewher inside the tub. Probably close to the front. also these front loaders have a big rubber seal, check and make sure nothing has fallen in between them. They make a specific product for cleaning these machines, sell it on same isle as detergent.
Jul 19, 2009 | Samsung WF337AA Front Load Washer
The clothes smell if left in the washer wet overnight
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Jun 07, 2008 | GE WHRE5260E Top Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
LG WM1812C Front Load Washer Logo
96 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
