Question about Canon MV700 Mini DV Digital Camcorder
What cable should I use to connect my Canon Camcorder MV700 to my computer Acer aspire L3600 ?
  • 11 Answers
SOURCE: Problem capturing footage from Canon MV700 DV camcorder to Windows XP
Hi
There is no reason why it shouldn't work. When you attach the camera via firewire the operating system will recognise and show an icon in the bottom right corner. Then whichever application you use to capture the video, when you select the option to capture video via DV it should bring up a little preview window with buttons for rewind,play,forward,pause,stop etc. using these onscreen buttons you can control the camera to set to the correct scene prior to capture. Also you might want to try not playing back a tape for capture but video directly through the viewfinder.
And yes its not that easy to edit DV video after capture. Though the quality is brilliant.
Posted on Nov 28, 2007
SOURCE: Canon ZR800 MimiDV Camcorder
I have the same problem, here's a 'sort of' solution. First check to see if your computer has a slot where you can plug in a PCMCIA card. (This is a thin slot about 2" wide, which probably came with a plastic blank inserted in it, which must be removed before using the connection. This type of connector is very common on laptops, less common on desktop computers. If your computer is a laptop, the PCMCIA slot is probably on one side or edge of the computer.) So, if you have a PCMCIA slot, you can buy a PCMCIA / Firewire card that plugs into the PCMCIA slot and provides you with one or two Firewire connections. Look on Ebay, these can be had for under $20. You would also need a cable with the tiny USB connector on one end (which plugs into the small female connector found uinder the gray plastic cover on the side of the ZR800) and a 6-pin Firewire connector on the other end (which you would plug into the PCMIA / Firewire adaptor card mentioned earlier.) When shopping, you may see IEEE 1394 terminology - this is the same as Firewire.) By the way, the adapter card may come with the necessary cable; see what you get before buying an additional cable separately. You will also need some software - I'm using Windows Movie Maker, which is probably already on your computer. If not, you can download it for free from Microsoft. Plug in the adapter card and turn on your PC. You should get a 'new hardware' message when it boots up. Wait for the boot up to finish, then connect the ZR800 via the cable to the PCMCIS / Firewire card and turn on the camera. You will get another 'new hardware' message as Windows recognizes the ZR800; wait a while until the 'Your new hardware is installed and ready to use' message appears. When the camera is recognized, you may see a window asking what program you want to use to capture video - select Windows Movie Maker. Once it (Movie Maker) starts up, get your camcorder tape ready, click 'Capture from video device' on your PC, then click 'Start Capture'. It will create a file (you pick the name) on your PC from the camera. You can use Movie Maker to edit, re-sequence the scenes, etc. (You can also buy video editing software if you want fancier features than Movie Maker provides.) Now here's the catch - why my initial statement says this is a 'sort of' fix. I hooked up my ZR800 as described here to a one-year-old Gateway model W323-UI1 laptop, and the video captured from the ZR800 contained many ramdonly blinking colored pixels superimposed on the movie and the audio has lots of static. When I hooked it all up to an older Dell Inspiron 8200 laptop, it worked great. Hope this helps, good luck!
Posted on Feb 22, 2008
SOURCE: canon mv700
cerco driver x canon mv700 grazie
Posted on Sep 16, 2008
  • 11 Answers
SOURCE: canon mv700
Hi
I have had this camera for around 4 years now. It works fine. I basically plug in the firewire connection on my camera switch it on to playback/camera mode then plug the other end into to my computer my operating system picks it up fine without any problems. It doesn't require any drivers windows will auto install any drivers it needs. Not sure why you are getting this problem.
Posted on Dec 09, 2008
robmcd27
  • 423 Answers
SOURCE: I'm looking for a cable...
Hi there.
Does your dell computer have a firewire port? That's what kind of cable you need. If so, great, buy one of those at any electronics store. If you don't have a firewire port on your computer, the you can buy a hub that combines both ports in one box.
Note: there is no coverter from one to the other as they are completely different technologies.
Rob
Posted on Feb 25, 2009
How can I connect my Canon Camcorder MV700 to my computer Acer aspire L3600 ?
Please refer page 118 of the manual of Cannon MV700 available from this website.
http://files.canon-europe.com/files/soft24377/manual/MV690_MV700_Series_CUG_EN.pdf
You can connect camcorder with Acer Aspire using a USB port and cable.
But this interface only allows transfer of still images from the SD card on the camera. It will not allow video images to be transferred from the tape.
Some models of Acer also have flywire interface (IEEE1394) and also SD card reader. You can use these also to download video images from the camcorder.
May 07, 2014 | Canon MV700 Mini DV Digital Camcorder
I am wanting to change my broadband connection to a wireless connection to use with multiple connections. Does the Aspire L3600 have what is needed for a wireless connection? I can't find any details.
The Acer Aspire L3600 only comes with a wired network option in the original basic configuration. Some models had an added WLAN card filling the mini-card slot. The best way to check if the WLAN card is in your computer is to check the Device Manager. In Windows Vista, Click Start > Control Panel > System and Maintenance > Device Manager (except in the Classic view of the Control Panel). For the Classic View there is a direct link to the Device Manager on the Control Panel. For XP, it's Start > Control Panel > Performance and Maintenance > Administrative Tools > Computer Management > Device Manager (in Classic View, just skip the Performance and Maintenance step). If you upgraded to Win7, Start > Control Panel > Hardware and Sound > Devices and Printers > Device Manager. Scroll down the list to find any Wireless drivers that are installed.
(If you have one of the machines with Unix, check the specific documents. My Unix experience has always been wired.)
The Aspire L3600 specs are available here: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireL3600/AspireL3600sp2.shtml .
I hope this helps.
Aug 10, 2011 | Acer Computers & Internet
Instruction manual for camcorder canon MV700
You can download and print the instruction manual in PDF format by clicking this link
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader
Thanks for using FixYa
Sep 22, 2010 | Canon MV700 Mini DV Digital Camcorder
I want to get driver tv tuner for acer aspire l3600
It's a problem for us to assume since you didn't mention the Operating System installed on the Acer Aspire... moreover there are two types of tv tuner card that comes with this model. I hope you'll not mind letting us know all these next time so that we can help you better.
If the operating system install on your system is Windows 7 the click the below links to download
Acer Aspire L3600 Connexant Tv Tuner driver for windows 7
Acer Aspire L3600 Yuan Tv Tuner driver for windows 7
Once you click the link, download will automatically begin. You'll need winrar or winzip to extract the files. Extract the files and run the setup or as per your convenience.
Acer Aspire L3600 Yuan Tv Tuner driver for windows vista
Currently, there's no drivers available for windows xp but you can still run it by using the "Device Manager" > "Update Drivers" wizard after extracting the windows vista drivers.
Good luck.
Thanks for using FixYa.
Jul 08, 2010 | Computers & Internet
My Acer l3600 Power Lead is faulty - is it
No. It's about 90-100 volts different.
Oct 29, 2009 | Acer Computers & Internet
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Canon mv700
Hi
Nov 09, 2008 | Canon MV700 Mini DV Digital Camcorder
Canon mv700
Aug 15, 2008 | Canon MV700 Mini DV Digital Camcorder
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
Canon MV700 Mini DV Digital Camcorder Logo
27 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
