Question about HP Officejet Pro X476dn MFP
My HP Officejet Pro X476dn Multifunction Printer wont turn on
  • 159 Answers
SOURCE: HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Posted on Mar 15, 2010
  • 5468 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
  • 4350 Answers
SOURCE: I want to run my
There is a button, on the printer, usually. This printer should be network cable attached and not USB. USB requries a host system and that host needs to be running and have sharing settings set to share.
MUCH better to connect the printer directly to your router.
Posted on Oct 17, 2010
SOURCE: Hp officejet pro L7780
I just did the full resetting, hold # + 9 while is on (is what i did) and i unplug the power cord just one is back of the printer, and released for a while to connect again power cord, so when printer star back on, i hold again # + 9 for a 15 seconds, and power off for a moment, later push the power bottom and start a blue screen with FULL RVRAM something like that, leave the printer , is gonne make alignments and so on , so after 10-15 minutes AWSOME , factory reset setting, GOOD LUCK
Posted on Dec 30, 2010
gabriel_silc
  • 25 Answers
SOURCE: HP Officejet Pro K5400 printer catridge stalled
Usually this defect is caused by the cleaning station that may be stuck.
Posted on Apr 26, 2012
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How do I reset an officejet X476 printer
Keep in mind that these instruction clear everything. The challenge is that if your control panel is locked you may not be able to carry out these instructions. 25371336-krtaiyymi0dz0suct32fia1z-1-0.jpg
Jan 16, 2015 | HP Officejet Pro X476dn Color Inkjet...
How do fix,hp officejet pro x 476 ,problem with printer or ink system.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | HP Officejet Pro X476dn Color Inkjet...
Hp 8500a910 all in printer continuous now printing message and wont print
The foam padding under the print head slide rail had lifted slightly catching the underside of the print head, which in turn causes the alignment to fail.
Nov 11, 2014 | HP Officejet Pro 8500 A910A Multifunction...
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Need user manual for officejet printer 4 in 1 8500
    Here is a link to the user manual and other documentation for the hp officejet 8500 multifunction printer
    Feb 08, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    When I go to scan it tells me 'no scan options'. Have I bought a very large printer only?
    According to the model specification the HP Officejet Pro L7480 is a scanner and a printer http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06b/18972-18972-238444-3328086-3328086-3446481-3446611.html plese check this link and confirm the model etc. Also do check if you have installed all the drivers and softwares required properly.
    Jul 05, 2009 | HP Officejet Pro L7480 All-in-One...
    HP OFFICE JET PRO L7500/L7600/L7700
    my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
    Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
    HP Officejet Pro X476dn MFP Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
