Question about ZAGG Computers & Internet
How to unstick zaggfolio keyboard - ZAGG Computers & Internet
How to go from touch screen to zagg keyboard and visa versa
Depends on the system you're running as well as BIOS settings
May 10, 2015 | Computers & Internet
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
My wireless keyboard does not work with vmware
Are you using Vmware View when logging on? It could be recognizing it as a usb device. Look on the menu bar that shows up if you bump the top middle of the screen under usb devices. If your keyboard is listed remove it or add it. One should make it work.
Oct 21, 2012 | ZAGG Black Carbon Fiber OEM ZAGGfolio...
Lenovo ThinkPad, keeps ticking & says I have a stuck key (42). Why? It's not responding
Your keyboard (or keyboard controller or ribbon cable inside the laptop) is sending a signal to the board that a key's pressed. Press each key down and see if any of them 'unstick'. If none of them unstick, prepare to send it back in for repair.
Jan 07, 2011 | IBM ThinkPad T42 Laptop
How do you switch from using the blue coded keys to the regular keys...my keyboard is using the blue coded keys like this one é and I cannot make it stop.
The blue-coloured 'fn' key must be "stuck" in the "down" position. Tap it, a few times, to "unstick" it.
Or, replace the keyboard.
Mar 02, 2010 | Gateway 2520796 Keyboard
Computers & Internet Logo
64 people viewed this question
Top ZAGG Computers & Internet Experts
richie46
jamulder513
Are you a ZAGG Computer and Internet Expert? Answer questions, earn points and help others
