Question about Palm Treo 650 Handheld
Factory reset nokia 9300 - Palm Treo 650 Handheld
I'm trying to rest my mobile Nokia 6700 to reste factory asking for security code
Hello it is not a hard task just follow this How to Generate Your Phone Security code..Only for Nokia bb5 to generate the security code.First thing you need to collect is nokia USB compitable cable.After you got the code,easily restore your phone with the generated code.Good luck.Thanks for visiting fixya
Jul 09, 2012 | Nokia 6700 Classic Cell Phone
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
How code format nokia 9300 comunicator
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370# then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Nov 09, 2010 | Nokia 9300 Smartphone
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
What is the format code for n 9300
Pull the battery out (or use a program like Roman Keller's Rebooter) and when the Nokia big and little hands are showing on the screen, press the CTRL, SHIFT and 'F' key at the same time. Your Nokia will be reset to its FACTORY state and ALL data will be lost, so be warned!
Aug 06, 2010 | Nokia 9300 Smartphone
I'm using nokia 9300, & i turned it auto restart
Looks like you have a corrupt firmware. You need to reflash it with a new firmware. take your fone to some softwre repair person.
Mar 03, 2010 | Nokia 9300 Smartphone
NOKIA 9300 FORMATING CODE
this code is not working
Feb 28, 2009 | Nokia 9300 Handheld
Is there any code to format 9300 handset?
hello,
you can reset your handset by any one of the following ways:
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, and then it asks for your security code (by default it is 12345) and then Yes.
Soft Reset: *#7780#, 12345 and then Yes. (Also works on Nokia S40 phones as a full reset)
Good Luck!!!
Jan 16, 2009 | Nokia 9300 Handheld
Not able to view messages & calls
Try to to do a soft reset to refresh phone main memory. If it is not working then you ahve to be aware that you need a hard reset the phone on order to bring it back to factory pre-set but you will have to loose all your own stuffs there beside factory pre-loaded stuff so backup your phone data before taking this action. Good Luck
Apr 10, 2007 | Nokia 9300 Handheld
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
