Question about Canon EOS 550D Rebel T2i Digital Camera
Canon EOS 550D doesn't turn on.
There's not problem in LP-E8 battery, but does 550D have cr2016 in it, and how I can change it to new one? Or anything else can be wrong?
dlundmark
  • 797 Answers
SOURCE: Error 99 in EOS 400D
Here is a link which may help you.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=9598105
It may be that the contacts on the lens is dirty, follow the directions, by using a clean pencil eraser (I would also suggest to use alcohol and clean the contacts after using the eraser). Also to remove the date button battery and the other batteries, then turn on the camera (with all batteries removed).
Then put the batteries back in.
Posted on Aug 24, 2008
  • 44 Answers
SOURCE: canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Posted on Dec 12, 2008
SOURCE: How to replace cr2016 from 450d/XSi or 500D/Xt1
The other bloke doesn't know what he is talking about..this is plainly obvious.
Looks like the CR2016 is inside the battery compartment under a small cut-out plastic piece (on same side as hinge). Use a torch and you can see it under this plastic piece.
You either need to dissemble it to get access or break off this plastic cover to replace...or take it to canon.
Posted on Feb 25, 2011
LogicX
  • 93 Answers
SOURCE: My new canon rebel T2i/EOS
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
Posted on Mar 12, 2011
SOURCE: my battery for canon camera 550d flashes orange
How long that takes to full charge canon 550d battery ?
Posted on Dec 31, 2012
My canon 550 d camera lens dose not zoom autormatically
a 550D is a detachable lens camera and will not auto-zoom (it has a rubber ring that you turn to accomplish this with most lenses). are you sure you have an EOS 550D, or did you mean auto-focus?
Apr 24, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Tip
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
on Jul 13, 2010 | Cameras
Canon EOS 550D won't turn on
If you have Magic Lantern installed on your camera and it won't turn on, all I had to was re-format the SD card. Works perfectly now. You just need to get rid of ML.
Jan 15, 2012 | Canon REBEL T2i EOS 550D Digital Camera...
I was wondering if I can use an LP-E5 Canon 500D battery for my Canon 600D?
No. The 600D uses the LP-E8. This is the same battery as used by the 550D, but not the 500D.
Sep 22, 2011 | Canon EOS 600D Rebel T3i Digital Camera
When The battery on my Canon 400d goes flat it loses the date and I have to re set it. I didn't need to do that until recently.
There is a small backup battery in the main battery compartment. I believe the XTi uses a CR2016 battery. It provides backup power to maintain the camera's settings when the main battery is removed.
Bob Kilbourn www.camerarepairs.com
Apr 28, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought a battery grip for my canon camera. but the grip ceases when i am using it for work. please help find solution
Is this battery grip a Canon or aftermarket accessory? Have you mounted the camera to a tripod if so what lens do you have on the camera? Are you using the adapter for the use of AA's or are you using the LP-E8 battery pack? Are you using the camera in portrait position or landscape?
Here is why Canon has had in the past some problems with battery grips but I thought it was a solved issue maybe not on the entry level DSLR's. What happens is there is enough flex between the body and the grip to break connection and yes it seizes up. Most Rebels will have a plastic lens mounting flange which will also flex with the weight of a lens (longer focal lengths). Also with the longer focal length lens it has more a tendency to flex the battery grip if mounted on a tripod. Holding in the portrait position the weight of the camera is actually pulling away from the contacts so there is a whole series of little possibilities. If it's a Canon accessory then it's a warranty thing if it's aftermarket Humm not sure should have something on it but, the quick fix is to keep tightening the mounting screw/wheel. I know that wasn't the fix you wanted but hey just telling the way it is.
Jan 17, 2011 | Canon Battery Grip (BG-E8) for Canon EOS...
Whats the difference between Canon EOAS 550D /Rebel / non rebel? Which is better camera?
Identical Canon models are sometimes marketed under different names in different parts of the world. Rebel cameras are known in America and EOS cameras are known in Europe. For example the EOS 550D is called Rebel T2i in America. They are in fact the same camera they just don't have the same name.
Nov 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Dec 22, 2009 | Canon EOS 450D / Digital Rebel XSi Body...
Jul 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
No Power To Canon Digital Rebel XT
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 550D Rebel T2i Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
