Http://192.168.123.254/setup wizard i i did not complete fixing the router
SOURCE: Unable to access the router for manual setup
i've had this problem myself setting up a wirless router connected to a ADSL 2+ modem
Pretty much both 'routers' compete to give everyone in the network an IP adress and get all muddled up between each other. So what i found that works is to turn off the option to automatically give everyone an IP adress/DCHP option on the modem and plug it directly into one of the network ports on the router (not the modem port). (changing the settings is done by connecting to the IP adress through windows explorer. ur manual should be able to help you with this)
Hope this works for you
Posted on Nov 09, 2007
carpenocte
  • 104 Answers
SOURCE: unable to access the set-up wizard to install my wireless router.
just reset the router... do you know how?
there is a small hidden button on it that you must press and hold for some minutes firs with the router powered and then with the router not connected to power line... Try this at leas 2 times with and 2 time without power, then try accessing the router as if it were new... with the default pass that comes in the manual...
Posted on Mar 17, 2008
SOURCE: Can't bring up Setup Wizard
yeah the same problem. not able to launch the wizard from the URL.
Actually i was trying to change the password for the wireless secure access and i tried typing different combinations and got in problem, then thought of doing a reset and start again the whole configuration, so i did used the reset hole and followed the instructions as listed in the document (ie like doing the configuration for first time). after restarting computer and access the http://192.168.0.1 URL, nothing happens, i'm not able to get the setup wizard. I also noticed that the LEDs are displaying properly as mentioned in the manual... now.. how to get it setup wizard....
plz help
Posted on Apr 15, 2008
cTech1
  • 66 Answers
SOURCE: Easy Install wizard problem
What you can do to fix this problem is not use the install program at all.
To configure your router, in your web browser's address bar, put the IP address of your router (Another belkin router's default IP was 192.168.2.1 out of the box) and click on go. This should bring you to the routers setup, and the password by default is blank.
Posted on May 16, 2008
CoquiBiz
  • 103 Answers
SOURCE: lost my setup wizard cd for a X-Micro XWL-11GRIX router
First, Go START | RUN... and type CMD.
When black windows apears, type ipconfig and write down the gateway. This is the address you have to use on your browser. The router will most probaly ask a login and password. Try admin for login and password. It change form manuf. to manuf. Search your Manual for Default Password.
Posted on Jul 13, 2009
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
I purchased a d-link device (model:dir-615) and i can't get it to install i am toddler in computer working
first you need to plug in your router to the internet with the ethernet cord from your modem once you have done this reset your modem by unplugging it or pressing reset button. Make sure your modem has completely rebooted, Then with another ethernet cord connect your router to your comp then turn on your router. Now once your router has completely booted up type http://192.168.0.1 into your web browser and hit enter. A login screen will appear and the default login is just admin, leave the password black. Now once you have done this there should be a link for setup wizard or it might be "wireless set up wizard". Click on that and follow the instructions. the only part you might be unsure of is the part where it asks you what type of interenet you have I do not know what you have but the large majority are dynamic and during setup it should be the default setting. After the setup is done you should be good to go GL
Jul 25, 2011 | D-Link Computers & Internet
How to change my password in wifi?
You can configure the router by running the Setup Wizard in the
CD-ROM provided in the package. The wizard provides quick setup
for the Internet connection, SSID, wireless security, firmware
upgrade and changing router's password. When you start the
Setup Wizard, you will get the following Welcome screen. Please
choose the language to start with and follow the easy steps in the
Wizard.
Manual Below:
http://www.edimax.co.uk/images/Image/manual/Wireless/BR-6226n/BR-622xN_Manual.pdf
May 10, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
An error occurs during installation
The CD Setup wizard will fail to complete the installation or sometimes fail to run at all because antivirus, anti-spyware or PC firewall is blocking the installation process.
To ensure a successful installation from the CD Setup Wizard, make sure all security tools are temporarily disabled before the installation begins. Enable back the antivirus, anti-spyware or software firewall once the installation is completed.
NOTE: If setup still fails to complete, check that you have selected the correct operating system in the setup options. You may also try restarting the computer and reinstalling from the CD if the setup fails to complete the first time. If all else fails, try searching for your device model at http://www.linksysbycisco.com/US/en/support/ and clicking on Get Downloads to download the latest firmware.
Nov 02, 2010 | Linksys WRT54G2 Wireless Router
I dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Feb 09, 2010 | Computers & Internet
Smart Wizard for WGT624
The Smart Wizard is on the CD, but the web setup is built into the router. There are 4 versions of the software, so click on the following link http://kb.netgear.com/app/products/family/a_id/1297
and select the version you have (it's on the label on the router), then click on the Documentation tab and grab the Setup (manual setup) instructions.
Carl
Nov 11, 2009 | Computers & Internet
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
