Question about Dishwashers
How do i fix bloomberg dishwasher door spring
  • 258 Answers
SOURCE: neff dishwasher door - think the spring has gone
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
leecom72
  • 4806 Answers
SOURCE: Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Posted on Feb 19, 2009
  • 258 Answers
SOURCE: kitchenaid dishwasher kudp01flss6
I managed to do it without removing the door, bit fiddley but have a look at http://www.howtofixanything.co.uk/howto-260.html
Posted on Mar 08, 2009
woodchuck789
  • 4070 Answers
SOURCE: door spring broken
You should have one at the bottom corners of the door. Pull the dishwasher out about a foot and you should be able to see the broken spring and the hooks it connects to. Screws under the counter top hold the dishwasher in.
Posted on Apr 22, 2010
SOURCE: Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Posted on Jan 13, 2011
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Door spring broken
Apr 22, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDK02CRBS the spring on the door broke? Is this a easy fix, where do you access the spring
Turn off the power to the dishwasher.
Remove the access cover on the bottom front of the dishwasher.
Lying on the floor,you can see the door hinges and replace the spring.
Feb 12, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
Nov 28, 2009 | LG Dishwashers
The spring on the door broke. How do we fix it?
get a spring from a kitchen aid parts supplier and relace it
Sep 28, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
Top Dishwashers Experts
