Question about Refrigerators
Instruction manuel hotpoint freezer model 8732
Defrosted yesterday, orange light still on at -20, why doesn't orange light go out
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
  • 16 Answers
SOURCE: have a hotpoint rsf60 fridge/freezer,noticed
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Posted on Jan 04, 2009
SOURCE: red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Posted on Sep 03, 2009
  • 691 Answers
SOURCE: i have a hotpoint freezer 8742 and the red light
if turning the power off for a short while doesn't work then the unit will need a technicians eye. I would expect it's a thermocouple or thermo switch, but worst case it could be that it's lost gas pressure
Posted on Jan 19, 2010
Defrost instructions
Manual Defrost model freezers must be defrosted manually. For best operation the freezer should be defrosted when the frost accumulation becomes 1/4 to 1/2 inch thick.Defrosting Instructions for Upright Freezers: Turn temperature control to OFF and unplug freezer.
Manual Defrosting Instructions for Upright Freezers
products.geappliances.com/appliance/gea-support-search-content?contentId=19298..you can also go to this link that should help you out... Defrost instructions Google Search
Oct 23, 2017 | Refrigerators
My Hotpoint Fridge Freezer 187P has Blinking Lights
Kindly upload pictures of the two lights flashing. What does the writing next to the two lights read?
Dec 06, 2017 | Refrigerators
Hi my freezer door on FFA70 Hotpoint isn't closing. I have taken the draws out and defrosted it. The door closes when none of the draws are in, but doesn't when the draws are placed in their...
Hi, I had exactly the same problem and eventually realised that the panel at the back of the freezer was coming loose. When I removed it I found that all the parts behind the panel were covered in ice, a lot of ice! So I have defrosted this ice using bowls of steaming water (not sure if this is an appropriate way to defrost, but it worked fine for me), I have also read you can use a hair dryer to spead up the process - apparently if you try and chip the ice off it can damage the parts in your freezer. I have now fixed the panel back on the freezer and it is working like new and I have had this fridge freezer for years now.
Aug 02, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Red light on Hotpoint Iced Diamond freezer
Aug 27, 2008 | Refrigerators
REFIGERATOR AND FREEZER NOT WORKING
Was the unit completly defrosted? Did the tech check to see if the compressor came on? Also, when the board is replaced, depending on the unit, there are wire to be cut so the board will work with that particular model. Check to see if the compressor is running first. then make sure the unit was defrosted. the other problem could be one of the thermistors deffrctive that control the defrost..
Aug 01, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
