Question about Pyle 2 Channel 4000 Watt High Power MOSFET Amplifier Car Audio Amplifier
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
SHOULD I GO AHEAD AND BUY A 400 WATT AMP NOW INSTEAD OF BUYING A 200 WATT AMP, JUST TO HOOKUP A 8 INCH KICKER SUBWOOFER ? WHAT IF I DECIDE TO BUY ANOTHER 8 INCH SUB
AND I ONLY HAVE A 200 WATT AMP WHAT DO YOU THINK?
THERE ARE SO MANY CHOICES OF AMPS FOR A SMALL PRICE
KICKER
BOSS
SOUNDSTORM
LEGACY.
WHAT DO YOU THINK?
    Problem Solver:
  • 5 Answers
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Posted on Jun 22, 2009
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Bought some 6x9's now need an amp to power them up cause my headunit is weak.. umm any advice on what amp to get.. i only need to power 2 vibe qb69 6x9s so do i need a minimum 2 channel amp? hope you can...
I know this is a very broad statement, but your budget will allow for what you buy. You will want a nice 2 channel 50 watt rms amp min. 50 watts is a lot of power for those speakers and you will be happy. I would recommend if your budget allowed a nice kenwood, Alpine, Diamond Audio or MB quart. Just make sure whatever you buy that it is a low noise A/B class amp. Nothing to special.
Take care and have fun!!
Jun 03, 2009 | Kicker KX500.2 Car Audio Amplifier
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Pyle 2 Channel 4000 Watt High Power MOSFET Amplifier Car Audio Amplifier Logo
140 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
