Question about Panasonic Audio Players & Recorders
Denon dm 37 thermal fuse keeps ressetting - Panasonic Audio Players & Recorders
My KitchenAid Architect Series II Electric Range after I ran the self clean option the oven door will not open and the display does not light up, the top burners work just fine, tried ressetting the b
Hello Gene,
On the back of the oven is a thermal fuse that probably went outduring the sefl clean cycle,ya would need to pull the oven out and remove the back panel to test it, That thermal fuse is not resettable and must be replaced,it probably looks something like this 11_15_2011_7_41_32_pm.jpg
GENE
Nov 15, 2011 | Kitchen Ranges
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
We have a mitsubishi diamond television the timer keeps turning off and now the television wont turn on at all
hi,
Your tv have problem with Digital module DM board. there seven filter capacitors (1000uf 16V ) in the DM board. if any one of it is faulty the this problem can occur. its a regular complaint for this model. just replace the capacitor. i have added the picture of the DM board you have to replace the marked capacitors . Also check the two fuses in the same board 4Amps fuse and 2Amps fuse.
ok
Jun 08, 2011 | Mitsubishi WS-65909 65" Rear Projection...
Help not cooking
Hi, fuses are common problem in ovens, try to check fuses including the ressetable thermal fuses.
Mar 07, 2011 | Emerson MW8991SB Microwave Oven
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Ariel connection for denon dm 31
try going to your local tv store and ask for a male to male connector it looks like this:http://www.firefold.com/Products/RCA-Male-to-Male-Adapater__RCA-MALE-MALE.aspx
Dec 02, 2007 | Audio Players & Recorders
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
