Question about ASUS A7N266-VM Motherboard
Display problem. How can i test whether my on board display card is working or not?
  • mlsantana Jun 22, 2009
    My onboard display card is a problem.How can i check that,and if there is a problem,cause the screen do not want to show anything when i power on.
  • Jacob Blackwood
    Jacob Blackwood May 11, 2010
    Not sure exactly waht your asking but download this, install, and see if its what your looking for. http://download.cnet.com/Everest-Ultimat...
    Ofcourse its the free edition so its not gonna tell you everything but it does help.
  • 90 Answers
Plug your monitor into the onboard video and make sure your bios options have onboard video turned on and fire it up
Posted on Jun 22, 2009
  • Troy Anderson Jun 22, 2009
    The method I gave you is to test if your onboard video is working. If you are looking for other ways to test this you will at least need another video card in it that works so you can see the screen to run hardware test/change settings. Please do not give bad ratings when you post little to no info and a tech makes a stab at helping you. Does not encourage the experts like myself to help you.
My computer cant display anything but it normally comes on as usuall
after switching on everything check backside of your system (cabinet) - fan must be running normally - if it is running slowly or if it is not at all running then SMPS is deffective - IF FAN IS RUNNING NORMALLY THEN .....switch off everything - remove monitor's cable from system (cabinet ) & then switch on only monitor - then you will get ''no signal '' or some display or some colour on monitor - that means your monitor is ok & problem is with system - if you don't get anything then your monitor is deffective - IF MONITOR IS ALSO OK THEN.....switch off everything ....open cabinet's cover ...observe carefully ...on main board 1 cell (round shape)will be there - remove it & check its voltage using multimeter ...it should be atleast 2V & above ....maximum it will be around 3.2 V - if it is not ok then replace it ....IF CELL IS ALSO OK THEN ....remove RAM & re insert (in same slot or another slot)......then switch on .....if it works ok otherwise for testing purpose bring same type of RAM & fix it & check......if it works ok then RAM is deffective OTHERWISE ......there is a problem in main board................if you are using display card (graphics card ) then remove it & reinsert on another slot .....also observe on graphics card whether any capacitors are blown ......on main board also observe whether any capacitors are blown.....if possible for testing purpose bring 1 graphics card & check it ......technical person can do all these things easily ....for non technical person it is difficult............so if you can do ....try it otherwise call service engineer................iam babu - service engineer (computers, laptops, printers, etc..) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com ....
Apr 13, 2011 | Dell Dimension 2400 PC Desktop
No disply p5vd2-x
Hello, If there is no display, then follow this steps to troubleshoot it, As it been displaying before and suddenly stops displaying, if your answer is yes then start with 1 check whether there is power to the board i.e power gets to the motherboard 2 Check the cmos battery,whether it is still ok, you can find the cmos battery on the motherboard 3 Check the RAM or memory whether it is firmly connected to its slot and working good 4Check whether your VGA chip on the motherboard is good if not you have to get an external VGA card and plug it on one of the slot either PCI or AGP slot. 5Check the data cable to the monitor, if it is still good,by removing it and testing it a good one. 6Check if the problem is not with your monitor either CRT or LCD by testing with a good one. If the motherboard is a new one and is not displaying , i would recommend you return it and collec a new one regards
Nov 26, 2010 | ASUS P5VD2-X Motherboard
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
The monitor will not display or power up. I've
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA703B LCD Monitor
My d845 mother board dont display
Its probably caused by the RAM, have it checked. If you can do it yourself, clean the RAM as shown in the image below:
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
In case your computer has 2 RAMS installed, clean them both. To test if there is a busted one, install the one then turn on the PC, if it works shut down the PC. Then try the other one, if it works too then it just needs some cleaning. But if not, one of them needs replacement. You can still use your computer with 1 RAM, just don't expect the same performance as having two RAM. Resetting the CMOS may also help you in the process.
Please reply if this has helped you. Thanks.
Oct 26, 2009 | Compaq Evo D310M 845G P4 Motherboard
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Black screen when starting a game
check for the video card speed requirement of your game. it might be too high for your video cards, a 256MB video card could not display a game with 512MB video card speed requirement.
May 20, 2009 | Acer V193w LCD Monitor
NO VIDEO
Are you using the onboard video or a display card adaptor?
1. If you are using the onboard video then try installing a known working PCI or AGP display card to test if the problem is onboard video or the actual motherboard.
2. If you are using a display card then try another known working display card (PCI or AGP) to test whether it's your displaycard that is faulty.
3. If it still doen't work then try removing your memory modules on the motherboard and replace them with known working memory.
4. If it still doesn't work then try removing your CPU and reinserting it again (be carefull as you do not want to damage your CPU!).
5. If it is still not working then you may need to replace your motherboard or take your PC into a repair facility.
Thanks
C
Apr 03, 2009 | Cornerstone FIC AM37-L Socket A XP...
No color on secondary display
Dear Huzzah,
please try to re-install the software( driver) of Radeon 64mb 9550/X1050 secondary series maybe the software is crroupt, if still face the same problem then please contact to Vendour to replace this card, if this card is in warranty period.
Regards
Scorpionakku
Oct 07, 2008 | Diablotek RADEON 9550 Video Card - 64MB...
Restart
Hi:
Test your memory.
Check one stick at a time and use a program such as memtest86 free for use. http://www.memtest86.com/
Memory can cause these problems.
The mother board could be the problem.
Try another display card in one of the pci slots. See if the display will work that way.
If the internal display is not working right, you may be able to turn it off. Or just use another video card.
take care,
Aug 31, 2008 | ASUS P5P800S Motherboard
ASUS A7N266-VM Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
