Question about GE Profile JGP636 Gas Cooktop
GEXL44 burners light with match, but not with electronic ignition
All 4 burners can be lit with a match, but none with the electronic ignition. The over and broiler work just fine.
    Novelist:
  • 222 Answers
If u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Posted on Jun 23, 2009
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
May 02, 2015 | Jenn-Air Cooktops
XLo burners keeping clicking but don't light after the initial lighting
Electronic igniters go bad and they don't work well if wet. Make sure yours are dry and change it if it still doesn't work. If the burner lights with a match, gas is getting to the burner. If it doesn't light, have the line checked for a blockage.
Aug 17, 2014 | Thermador Cooktops
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
The burner will not click to light but will work when lit with a
replace the ignition coil if no sound clicking,but the parts is expensive? is ok to use macht.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Burner not lighting
Yes, you need a technician. It could be spark module or spark igniters on each burner.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 15, 2008 | Cooktops
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
504 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
