Question about Garden
Where can i get a belt routing diagram for a craftsman RER1000??
Need to know how to install a belt that runs the blades?
  • 93 Answers
First you will need to look under the seat and get the correct model number like 000.0000000 then go to sears.com under lawnmower parts and look up your mower which will give the parts diagram.
Posted on Jun 02, 2014
  • 496 Answers
SOURCE: need photo of routing blade belt for 42
I'm sending you a link for you to obtain a users manual for your mower.
To get the correct manual, you will need your Model Number and Serial Number... the website of the link will tell you how to obtain those from your mower.
The manual would be good to have, anyway and should illustrate the correct belt routing and many other specifics.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
Hope this helps... Good luck!
Posted on Sep 16, 2009
brado83
  • 106 Answers
SOURCE: need diagram for installing mower belt for blades
Hey if its a 42" cutter deck this should be the one:
http://i876.photobucket.com/albums/ab330/Brado83/JDDeck.jpg
It may be a 48" in that case it would be different
Brad:)
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
  • 351 Answers
SOURCE: i need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
Posted on May 12, 2010
  • 5370 Answers
SOURCE: i need to know how the pump belt is routed
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Posted on Feb 20, 2012
I need the blade belt routing for dys 4500 42" cut
Mike, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
craftsman dys 4500 belt diagram Google Search
Replacement Parts Accessories Sears PartsDirect
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0701547.pdf
EASY CRAFTSMAN DECK BELT INSTALLATION
May 07, 2016 | Sears Garden
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
How to put a cutting belt on a craftsman RER1000?
cutting or blade belts our not that bad if you follow these two things.Idler pullys that are flat ,the flat side of the belt goes against it. If the pully has a v in the pully ,the v side of the belt goes in the v most times you can figure it out as a lot of mowers out there and the decks are different
May 07, 2014 | Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
I need diagram to thread blade drive belt.
Route the deck drive belt between the two inner, forward pulleys and then out and around the outer blade pulleys.
Jul 30, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
Belt routing diagram
On link below on page 9 will show you the belt diagram.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L1001239.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 22, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
CRAFTSMAN Tractor Model%23 917257643 adjust idler pulley. I have the above lawn tractor. One day the mower belt shredded. I got another one and when I engage the mower it starts to shred. I think I need to...
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Oct 25, 2009 | Craftsman Garden
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replace primary belt
here you go. (should be a diagram pictured below). If no picture, then the belt routes from the engine pulley on both sides (goes around the pulley) and goes strait back in between the two smaller pulleys, one an idler, the other spring loaded tensioner. The belt goes left with one leg, right with the other (from front or back) and engages both pulleys. Then goes to both blade pulleys and around them, then "meets" each other at the rear of the deck, running  strait from one blade pulley to the other.image.tiff
Oct 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
