Question about ASUS Computers & Internet
How do i disable the touch mouse
Model ul50vt
  • 79 Answers
Go to the Control Panel and select Classic View (for easier approach), click for "Mouse" which will open the mouse properties. Click the tabs and look for the check box that says "Disable when external USB mouse plug in". Check it, press Apply then close. You can also disable the touchpad here for good by selecting "Smart-Pad" at the list and clicking the "Stop Device".
Posted on Apr 05, 2015
  • 70 Answers
Fn key+f9
How to disable/enable touch pad on hp 6735s
well you will have to go to your bios settings first and disable you touch within the bios. plz let me no if you need help with the touch pad
or bois
Mar 21, 2014 | HP Compaq 6735s Notebook
Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
Oct 15, 2010 | Dell U0636 Mouse
How to disable touch pad for dell precision m4500 model?
Please go to Control Panel->System->HW->Device Manager. Click on the Mouse and Other Pointing Devices. Select the Touch Pad and from Action in menu select properties. In Advanced option her you can disable the touch pad.
Sep 28, 2010 | Dell Precision M50 (PRECISIONM50) PC...
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
My touchpad has stopped working. Device Manager
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
I have model A355-S6935 its a new unit. My problem is when typing the type skips out of the sentence into the lines already typed. Is this a common problem as it causes major rework and is extremely...
easy, your touching your mouse pad (square you touch to move the mouse), you can turn it off and use a regular mouse, turn off the laptop, plug in a mouse, windows will automatically detect it.
On every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Make changes to the mouse and mouse pointers in the Mouse Control Panel. To open Mouse, click Start, click Control Panel, click Printers and Other Hardware, and then click Mouse.
Good luck,
Mr.Fix-it-guy
Aug 13, 2009 | Toshiba Satellite A355-S6935 Laptop
Computers & Internet Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
