Question about Maytag M7D24E7A Air Conditioner
My window unit air conditioner will not turn on
I had not used the window unit all winter and spring and went to turn in on and it just blank... no lights or anything.... ?
  • 49 Answers
SOURCE: Kenmore Air Conditioner
You must be referring to your outdoor condensing units. Yes it would be ok to cover and disconnect power, but I would suggest turning power back on, uncovering, and making a cooling test run long before you need it, after it warms up.
Posted on Nov 08, 2007
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
koolbreezes
  • 540 Answers
SOURCE: window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Posted on Sep 02, 2008
  • 958 Answers
SOURCE: Window air conditioner storage
sure you can but you have to prepare it for the winter.
re-oil the fan motor and make sure you wrap the whole unit up with a plastic wrapper just like the one used in the kitchen, the one that you can stretch to cover a whole stainless food container. then put it in a box to further keep the moisture away.
then after the winter and you want to use it again,
unpack it and inspect the fan motor. make sure that it is freely moving without binding or sticking.
let it stand for a couple of hours so that if there is dew inside , it would evaporate first .
then you can use it again.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
greg_margo
  • 1959 Answers
SOURCE: 2003 Pontiac Sunfire sending unit
Check the pressure in the low side A/C line. My guess is the refrigerant is low and needs recharging.
Posted on Apr 26, 2009
My AC unit's fan suddenly started to make allot of noise, how do you fix this?
bearings in motor dry out and need to be oiled. a real problem when they set up with out running.
May 24, 2014 | Friedrich Uni-Fit US08B10 Air Conditioner
Tip
How to store you air conditioner for the winter?
Make sure that you tip the A/C unit to remove water that has condensed in it. If water is left in the system over the winter/spring, it can rust out the evaporators in the A/C and cause problems with its functioning. Also, the water can serve as a breeding ground for mold and bacteria.
on Dec 30, 2009 | Heating & Cooling
I have a AR-VS7 Fujitsu air conditioner that I have not used for a few weeks, I just went to turn it on but the remote screen is blank so I put in new batteries but it is still blank. Is there anyway to...
In many units no option to use manually without remote and also it's not advisable. With your statement, I conclude your remote is defective and not repairable. Replace with new remote. Helpful?
Jan 04, 2011 | Fujitsu Heating & Cooling
No start up
No its not. Bad valves are caused by dirty filers,dirty coils that cause liquid refrigerant to slug compressor and knockout the valves. Rus
Aug 17, 2009 | Ruud UAMB Air Conditioner
Goldstar GWDH 5000 does not cool after storing this winter
sounds like low freon or a blockage in one of the lines, especially since the you say only one row of coils is cool. usually window a/c's have at least a 1-year warranty and since you are pretty close to that, the manufacturer may honor it. if not you will need to have the system fitted with a bullet piercing valve on the low side lines and see if the unit is low on freon with proper gauges. if it is not showing low then there is probably a blockage and the high side should be checked as well. if this unit was an expensive one it could be worth having it repaired. a simple recharge may cost less than a replacement, but anything else probably won't.
Jun 08, 2009 | LG Goldstar GWHD5000 wall/window Air...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Heating & Cooling
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
ACQ088MR
one needs to check if fans are running correctly otherwise, gauges need to be connected onto system.  assuming the condenser(radiator) is clean.
May 23, 2007 | Whirlpool Designer ACQ088MR Wall/Window...
Maytag M7D24E7A Air Conditioner Logo
53 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
