Question about ART Cast Iron Coil Tattoo Machine Liner & Shader
How to fix tattoo power box
My power box stopped working and I don't know why? it made a sort of popping noise then stopped working its a ps128
Does anyone like full arm tribal tattoos or this one I have added in this question?
Well...I 'm a girl and i think tribal tattoos are really hot! i would love for my guy to get tribal tattoo designs for men, so I could trace the designs that are across his shoulders, neck, stomach or arm's... with my finger tips i don't really like tattoos but tribal tattoos have something over me. so yes i like full arm tribal tattoos as long as ya don't go over bored ;) I plan on getting a tribal tattoo on my lower back sometime this year.
Sep 07, 2012 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Tip
Tattoos - Do They Hurt?
Tattoos can be a wonderful way of expressing art on the body, but you should always make sure you use a reputable tattoist and follow some basic health and safety guidelines if you want it to be a positive experience.
  • Just like with any cosmetic surgery, you should make sure that you choose your tattoo studio carefuly. Once you have a tattoo done on your body, it's not something that can be easily removed so make your choices wisely.
  • Yes, tattoos can be very painful but it's not a pain that is unbearable and everyone reacts differently. Your attitude to pain and how relaxed you are feeling will greatly affect the outcome.
  • The skill of the artist definitely has some bearing on the amount of pain you'll feel. An experienced tattoo artist will know how far they need to be pushing the needle to get the effect that they want.
  • You may be offered a numbing cream but these don't work beyond the top level of skin and as tattoos are done on the second layer of skin, these creams really don't do much to help.
In summary - yes tattoos do hurt but so does waxing and having your eyebrows plucked. Just make sure that you trust your tattoo artist and that you are relaxed.
on Oct 07, 2013 | Medical
How to set up tattoo gun
If you don't know the answer to this question, you have no business owning it.
Aug 07, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
MY TATTOO MACHINE IS GETTING HOT
too much voltage, too much amperage, your springs may be too heavy, and the return on your armarture/contact spring should be bent just a little to help it assist forward motion in the direction of the coils. play around with the armarture height and bend your springs while trial and erroring (*******, i know it's not a word) at low voltage like 5.5-7.5 volts. if it hits hard, sounds consistent and doesn't kick back or stick you won't overheat. A better power supply may just be the ticket though. spend at least $80 bucks on one. anything cheaper will feed too much power, inconsistent power or will not feature short circuit protection so the moment a coil stick happens your PS blows. stay away from digital power supplies (the little dinky box ones that look like late 90's GPS beacons) and only run your machines momentarily while tuning, when it's tuned you should know it immediately within the first few strokes based on the sound. You should already know all of this if you are tattooing, but I wont give you heat because I know some scratchers that do better work than Kat Von D and Tomas Tomas, just saying. If you are scratching please for the love of sweet baaaaby Jesus, ONLY USE DISPOSABLES and NEVER go without BARRIER PROTECTION aka, wrap it up. - Professional tattoo artist; Brian @ Foxy Tattoos, Raleigh, NC
Mar 12, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
Where do i attach the clip cord to the tattoo gun model d99
if you don't know, you shouldn't be tattooing... or it takes an RCA cord in which case your'e just a big dummy
Sep 30, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
I have a tattoo gun with no power supply. how can i make one at home?
get a **** power supply and don't be a dummy. you can get cheap one's and add a pc cooling fan so it wont blow up. that's the best you're gonna do if this is actually a concern of yours.
Jul 29, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
My power box is showing voltage but my tattoo machine is not working
I have never seen a tatto machine but plug something else into the same area and see if it works. Just a guess but you probably move around alot with that cord and that is moost likely the problem.
Jul 27, 2011 | Garden
I left the gas in the tank for almost a year, while i was undergoing chemotherapy, when i started it, it has aloud popping, no missing no loss of power, just the popping.
Sounds to me, like at least one of the cylinders is not fireing and the noise you are hearing is the cylinder attempting to come in, after a while does the popping stop?. Poss a new set of plugs will sort it out, it may even sort it self out with use
Feb 20, 2011 | 2003 Honda VT 750 C2 Shadow
When doing line work what should your power box be on,and do you run it slower or faster for shading
i believe your power box should be between 110 and 120....and for shading you should run it slower....somewhere between 75 and 85.
Oct 15, 2010 | ART Cast Iron Coil Tattoo Machine Liner &...
AIWA UZ-PS128 Software
re. "MUSIC TRANSFER SOLID MEMORY EDITION" software for the AIWA UZ-PS128
I have the cd that came with the headphones with version 1.1 of the software. The setup folder has zipped to 7mb so is small enough to email.
Steve Smith
Dec 05, 2007 | Aiwa UZ-PS128 128 MB MP3 Player
ART Cast Iron Coil Tattoo Machine Liner & Shader Logo
35 people viewed this question
Top ART Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you an ART Medical Expert? Answer questions, earn points and help others
