Have a new Sony DVDVCR RDR-VX560 (3 days old) seems to be locked up and cannot bring up menu with the Remote Control. When I press any button on the remote, DVD 3 appears on the front Panel. I did have it programed but now it seems to be locked. It will play a DVD by using the controls on the Recorder. Cannot turn recorder on or off with Remote.
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Was this helpful?
Yes
No
Popular Solutions for Sony RDR-VX515 DVD Recorder /
On My Sony RDR-VX560 I some how got the unit stuck on DVD1. Now it is locked up and I read in the...
(More)
On My Sony RDR-VX560 I some how got the unit stuck on DVD1. Now it is locked up and I read in the manual (Quote) " If the command mode for the recorder has not been changed, set the command mode for the remote to the the default setting of DVD3. If the command mode for the remote is changed to DVD1 or DVD2 you will be unable to operate this recorder." So does anyone know how to get it back into the Default DVD3 mode. I have held the enter key down for more than 10 seconds then pressed the System menu but nothing happens. Thanks in advance for any help
I have the sony rdr-vx525 cassette/dvd recorder. Made mistake trying to record a copy protected dvd....
(More)
I have the sony rdr-vx525 cassette/dvd recorder. Made mistake trying to record a copy protected dvd. Now I can watch a cass. or dvd. But when I stop the playback it will not show the program on the channel it is set on. Message (the DVI/HDMI output is blocked how do I reset. It also says press EXIT to cancel. Where is EXIT?
