Question about Primus BrewFire Coffee Brewer
Primus coffee maker won't light - Primus BrewFire Coffee Brewer
Can I exchange parts on HOLZ HER edge banders? 1st edge bander is a HOLZ HER 1436 S and the 2nd is HOLZ HER Primus 1436 SE PVC.
This doesn't sound like a
Question about Coffee Makers & Espresso Machines
I have recategorized to woodworking
Better to ask the makers
http://www.holzher-nullfuge.de/en/meta-navi/contact/
Aug 19, 2015 | Crafts & Hobbies
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
Descaling won't brew
Desacle now or it won't reset to factory settings.
Mar 11, 2012 | Keurig Platinum B70 Coffee Maker
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 13, 2011 | Keurig B100 Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
Only the large cup lights up and when button is pushed it won't brew.
heatman101
Aug 16, 2011 | Keurig B60 Coffee Maker
My light won't go out and I descaled it then one light on the cups only lit up and it only gives a little water it's the kuerig i don't know the model
heatman101
Aug 08, 2011 | Keurig B60 Coffee Maker
Primus BrewFire Coffee Brewer Logo
43 people viewed this question
Top Primus Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Primus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
