Question about Uniden Radio Communications
How to reset to factory original settings?
There appears to be a need to reset the radio back to the original settings as it is overloaded with mixed instructions
    Genius:
  • Uniden Master
  • 1,795 Answers
You need to get a service repair manual for the type radio you are talking about. you can go to www.cbtricks.com and get just about any manual you need. wouldn't buying another one be cheaper and better?
Posted on Aug 13, 2014
How do I hard reset a LG G3
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
Back up data on the internal memory.
From any home screen, tap Apps.
Scroll to and tap Settings.
Tap 'General,' then scroll and tap Backup & reset.
Select or clear the following check boxes:
Back up my data
Automatic restore
Tap Backup account and follow the steps to create Google backup account, if necessary.
Tap Factory data reset.
Review the warning message and select or clear.
Tap Reset phone.
Tap Erase everything.
Tap OK.
Master reset with hardware keys
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
Turn off the device.
Press and hold the Power and Volume down buttons on the back of the device.
When the LG logo appears, release and then re-hold the Power button while continuing to hold the Volume downbutton.
The Factory data reset screen appears.
Press the Volume down button to advance the cursor until Yes is selected.
Press the Power button to confirm.
The Erase all user data and restore default settings screen appears.
Press the Volume down button until Yes is selected.
The device will now reset itself. Wait until the process has finished.
Your device now has been reset to its original factory settings.
More informaton about phone repair guides and tools, you can choose Vip Fix Shop Team. Professional grade Phone Repair Tools for iPhone iPad Cell Phone One Stop...
Dec 14, 2017 | LG Cell Phones
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
All channels locked
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
BillB
Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
My pro-2096 does not display any letters or
To RESET:
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
All channels are locked out. how do I get them unlocked
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
I TWON'T MOVE. IT SAYS ALL CHANNELS LOCKED OUT. NEED HELP
If all else fails you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press ENT
BillB
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
Aug 07, 2009 | Motorola TalkAbout T5000 2-Way Radio
Radio Communications Logo
115 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
