Question about Straight Talk LG L40G Cell Phone
Headphone mode can't hear phone calls unless on speaker
Why is there no sound on my NoKia Lumia 520 windows 8 ?
I ran into this same problem with my Nokia 900. It happened right after I plugged and unplugged a headphone into the headphone jack, so I suspect Nokia ships with a defective headphone jack sensor, because this happened with the second phone after I returned the first one and got a new one. (Note to self, don't plug a headphone into a Nokia phone). I am able to temporarily get around the issue by going to the dialer and calling ##634#, then going to the audio loopback diagnostic and starting the loopback for the phone and choosing loudspeaker. This does not last permanently, so I have never found a solution to the issue, other than using blue tooth or speaker phone.
Jul 28, 2014 | Nokia Lumia 520 Windows Phone Black
I cannot hear while making calls. The volume switch does not work either. When I make a call the other person can hear me but I cannot hear anything. The system sounds and ringer volume are turned up....
When making calls, try putting it on speaker phone.
This problem is widespread, and it is due to a problem where the phone does not recognize that the headphone jack has been unplugged. This means that the phone will send data to the headphone jack, and not to the speaker anymore. You can try to 'unstick' it by inserting and removing a jack until it recognizes it, or repeatedly blowing into the phone's headphone port. Both of these solutions have worked for me, but they take quite a bit of effort, so I have just gotten into the habit of using speakerphone. For me it still works, event when the phone is in headphone mode.
May 01, 2011 | Palm Pre Cell Phone
I can't turn of this handsfree thing in my phone..
During phone call, do you see a 'speaker' icon you can press in the screen? It only shows when a call is active. It toggles between handsfree and fry-your-ear mode. If you are listening with the loud speaker and plug in your wired headset it will automatically go off speaker mode (takes a couple of seconds to work). You can put it back into speaker mode while the headset is still attached.
On mine, it remembers the volume I last used with the speaker, so if you had the volume down you can adjust with the up-down buttons on the right hand side of the handset.
If you have an older storm, I think the volume buttons have sometimes been reported to have problems. Whether you can fix that will depend on whether you are under a service contract for handset warranty or maintanance.
Sep 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
I cant hear!
your cellphone earpiece is damaged or loose contact.
Mar 12, 2008 | Sony Ericsson W600i Cellular Phone
Treo 600 can't hear without headset
Try blowing hard on the spot where the headset plugs in. I have this same issue on my treo and a good burst of air will at times bring back the speaker/microphone.
Nov 24, 2007 | Palm Treo 600 Handheld
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
Straight Talk LG L40G Cell Phone Logo
18 people viewed this question
Top Straight Talk Cell Phones Experts
justwinwin
Todd Arndt
Todd Arndt
Computer Repairing
Computer Repairing
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
