Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Where does this part go on my floor mate - Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Why is the red bar still showing when I've cleaned both filters?
If you hear the motor running you have to have an air leak. Check all areas where parts mate together or anyplace where there is a gasket on the mating surfaces.
Aug 10, 2014 | Hoover Vacuums
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
Cleaning Solution
The solution is called "floor to floor" sold in a white 48oz bottle
Jan 18, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floor mate
There is a little post in the back where you insert the top solution/water tank, if you put the tank in incorrectly, (i.e., shoved it in, instead of putting it in at an angle, bottom first) there is a chance you broke it or bent it backwards. My mother broke mine, i've got the post but don't know the part, without that post inserted into the tank the water will not come out.
Nov 06, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have misplaced my instructions and need to use it today
Thank You, but after I sent the FixYa mail yesterday, I finally found my instruction book.
I am not interested in a repair program at this time.
Diner
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have a hoover floor mate(the hard floor cleaner). The plastic solution cannister leaks through a spring plunger.
There is a rubber bushing that should be in there also. But replacing your tank may be the best option.
May 12, 2008 | Vacuums
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
