Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
How should the cutting blades be aligned - Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Need operators manual to remove brushcutter blade
Hi mine has a hole behind the blade that you put a screwdriver in then turn the blade till it goes in to an aligning hole then it's screws off
Sep 27, 2017 | Craftsman Garden
My RZ4824 Husqvarna zero turn mower cuts deep into the grass & dirt on zero maneuvering. it also does this deep cutting with reverse. Can you help me?
Check the blades are not bent or damaged, if ok check the deck alignment from side to side, measure the distance from the floor to the tip of the blade with the blade facing forward check both r/h and l/h blades.
Jul 24, 2017 | Husqvarna Garden
My craftsman miter saw cuts but it is not a straight cut.
Here's an old dude trick that might help.
Safety first! UNPLUG THE SAW.
- Take a framing square and set it against the fence. It should be flush with the fence on both sides of the blade. If not, slide the square to one side and pull the blade down into full cut position, then slide the square against the blade and fence to check for square. If square, slacken the bolts on the other half of the fence and align it with the correct side.
- A bit of messing about should have it lined up just fine.
- If it is off vertically, there should be some alignment possible.
Patience and safety.
You'll get it.
Oct 08, 2015 | Craftsman Saws
When ripping a board the width becomes narrower toward the end of the board, I have checked the fence and it is aligned correctly. the splitter is also aligned, replaced the blade and it helped did not...
Several possibilities come to mind:
1) Check the alignment of the arbor -- it's possible the arbor or arbor nut are not completely true. Detailed instructions are here:
http://woodgears.ca/saw_arbor/index.html
2) Check the alignment of the blade to the miter slots. If you aligned only the fence to the miter slots, it's possible the fence may not be aligned with the blade if the blade is out of alignment.
3) You said you checked the alignment of the fence and splitter, but these are the most common causes for the problem you're having. You might want to re-check the alignment of both, using a different method. Try these methods:
http://www.toolcrib.com/blog/2007/09/06/table-saw-alignment-for-005/
Be methodical and follow the directions for alignment closely. The extra attention you put into aligning your saw will pay you back many times over in clean, accurate cuts.
Aug 10, 2009 | Jet Saws
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Sep 03, 2008 | Wahl 9765-301
T-Outliner has stop cutting!
good advice but the best way to align is to know the exact aliment,pay attention to how the blades are set in relation to one another when they cut correctly,and remember this so that next time wont take so long to adjust the blades.
Mar 12, 2008 | Andis 01690 Hair Trimmer
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
