Question about Dometic RM2620 Refrigerator
Dometic rm 2620 fridge problem
Freezer works well but fridge section not working (on propane) fridge works well on 110 volt only
    Habit-Forming:
  • 62 Answers
The flame is not hot enough check gas pressure
Posted on Jul 24, 2009
  • 4stevetaylor Jul 25, 2009
    Not enough flame , flue cloged, not enough gas pressure, or the orfice is cloged
  • 51 Answers
SOURCE: Dometic RM 2804, freezer is
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Posted on Jul 06, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
SOURCE: My Dometic rv Refrigerator does not cool the lower
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
Posted on Jul 19, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
RM 2611
maybe bad 120 volt side of board that is bypassing thermistor
Apr 17, 2014 | Dometic Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Fridge works on propane but will not cool on electric. unit is a dometic american 10 years old.
Are you familiar with the location of your heating element for 110-120 VAC.
DO you have a multimeter, or AC voltmeter, and know how to use it?
Jun 07, 2010 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic fridge
I would look for a ventilation problem. If the fridge is working at that level nothing wrong with electric. The unit needs air to move up and out the top to make the freezer work. It sounds like the air is only moving the wrong way out the lower vent. Careful it could just be a birds nest but it may be a large wasp nest blocking the roof opening.
Aug 24, 2008 | Dometic RGE400 Top Freezer Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2620 Refrigerator Logo
473 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
