How do you remove the batteries to replace with new one's.
Please could you tell me how to remove the Bastteries
  • 36 Answers
Each item has its own way of holding batteries in an item. Most things have a spring clip cover over the battery that holds the batteries in place and you need to remove that before replacing the battery. Some covers can be held down with small screws. Some batteries are welded or soldered in place and you would be better taking these to your local tech guy to do these. Once you have the batteries in view note what size and which way round they are. The new replacement ones should be the same size, shape and voltage (power) you will see they have a different shape to either end of the battery.
The ends or terminals are marked + (positive) or - (negative). Mostly you can describe them as being flat (negative) or bumpy (positive) and any spring in the housing will go against the flat end.
Turn your device off, flip the old battery out (move the the battery against the spring end to release the positive end first - it is normally easier that's all.) and replace the old battery with the new one. Try putting the negative end in first to squash the spring and the positive (bumpy) end will fit easier. If there is more than one battery in line then you will find the bumpy end of one goes against the flat of the other. Still the same, flat end of the first battery then the second battery with its flat end against the bumpy end of the first one. Put the cover back on and switch on........
Don 't forget to dispose of the old batteries according to your local ordinances as they do contain fairly poisonous chemicals that can leach out into the soil if incorrectly disposed of.
It would help if we knew which device held the batteries as they may not be the small round tube shaped ones .....
Posted on May 08, 2014
We have a CyberPower 485VA. It looks as though the battery needs replacement. Can you tell me please, what do we need to do in order to have the battery replaced on this product?
The user manual, here; http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBQQFjAA&url=http%3A%2F%2Fwww.cyberpowersystems.com%2Fuser-manuals%2FCP485SL_UM.pdf&rct=j&q=485VA%20manual&ei=xv5rTcyfFIK8lQfK1Z3sCA&usg=AFQjCNEwLJWkSdw8vYNqlu0cht9jAO2jmA&sig2=0-4DgQzCfnq37_2SSTmJ9w&cad=rja will guide you through removing the battery and installing a new one. You can buy a new one here: http://www.batteryuniverse.com/UPS/CyberPower/485VA/VRLA1250_CyberPower_485VA_UPS-Battery
Feb 28, 2011 | CyberPower 485VA UPS Backup (BE485) UPS...
I just replace the battery in my APC RS 900 unit because the red indicating light was telling me to do so. I installed the new battery and the red indicating light is still telling me to replace the...
Sorry to read about your problem, I hope this helps you out.
let it charge 24 hours, and see if it works
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | APC Back-UPS RS 800VA UPS System
I am using Norelco Quadra Action 7617X, I had take this machine some times back like two years ago but I was not using it. Now I wanted to use it but after charging it does not hold charge. If I charge it...
It does sound like you need new batteries. Batteries for your shaver must be soldered in place. You will find battery pack for this model at shaveroutlet.com. Link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To replce, first open the shaver by removing the screws on the back. The back cover can then be removed and you can access the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See info link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Sep 20, 2010 | Norelco Quadra Action 7864XL Electric...
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Sep 12, 2010 | Braun Health & Beauty
I need to replace the batteries in a quickie rhythm wheel chair, can you please tell me how to get to the batteries to replace them?
If you are able you need to remove the seat. Lift up on the lever on the right side under the seat and lft Don't forget to disconnect the joystick cable that goes into the shroud near the seat post. After you have gotten the seat out of the seat post remove the shroud covering the base by pulling up to relaese the velcro tabs. You should be able to see the batteries. Disconnect the cables and lift out each battery. Replace with new ones making sure you reattach the wires to the correct polarity. Red to pos black to neg. Hope this helps
Aug 16, 2010 | Quickie Wheelchairs Quickie Aspire Power...
My 550 remote stopped working. The light under "activities" goes on, the bastteries are good, but nothing else works. Please help!
Please try re-installing the firmware.
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 24, 2010 | Logitech Harmony 550 Remote Control
Thanks for helping, i would like to change the battery on my 2003 road king but do not know how. can you please tell me?
Rmove phillips screw holding down passenger pillon. Pull pillon back and up a little. Take 5/8" wrench and remove "nuts" now exposed. After removing pull seat up and back over studs. Battery is now exposed. Remove right saddle bag, right side cover, remove ECM fuse. Carefully remove 10mm(?) bolts holding battery cables on, before hand note and or label other connections if present. Lift battery up and out, replace with new, reverse steps.
Important note, battery is very tight fit, and must sit firmly in battery bos, and ALWAYS use a sealed battery. The cost $100+.
Hope this helps,
JP
Dec 12, 2009 | 2005 Harley Davidson FLHR - FLHRI Road...
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Replacing battery cover door on Canon AL-1
Very easy to replace door. Remove base plate (3 screws). Remove 1 screw found in battery compartment. Lift corner of battery compartment (right where you took the screw out) up about 1/4". No more or you will break the opposite corner. Use a piece of picture hanging wire and push the hinge pin from the outside toward the inside until you can grab it with tweezers and pull it right out. Rest is simple.
Sep 09, 2008 | Canon Photography
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
