Question about Cleveland Range Cleveland KGL-60 Kettle
Cleveland gas steam jacketed kettle not heating up
The kettle heats up when initially used. Subsequent use the kettle does not heat back up
Tip
Hot Water Steam Efficiency Plus Comfort
Steam heat is a great warm, wonderful, and absolutely fabulous way to heat your house. Steam heat is almost always created from water in a boiler fueled by gas, oil or electricity. It then passes through pipes and radiators or convectors to heat your home. A steam heating system uses steam that is generated from a boiler. When the water boils, the steam rises through the pipes and into the radiators to heat them. The hot radiators then heat your home.
Steam is a great heat distribution medium because it moves easily through your system and it has an extremely high heat-holding capacity. The heat-holding capacity of steam is much greater than that of water. Steam heating systems often operate at very low pressures and usually under 220°F. Steam heat is usually distributed by either one or two pipe systems. In a case of a one-pipe steam heating system, a single main serves the dual purpose of supplying steam to the heat exchanger and allowing condensate to run back from the radiators also. A two-pipe system has two connections from each heat exchanger or radiator. In this system, steam and condensate flow in separate piping from each other. With a steam system all pipes must be well insulated and you must use pipe insulation rated for steam piping. If the insulation is removed the system will no longer work as designed. Noise and all sorts of problems will come from uninsulated piping.
When you have radiators on upper floors or radiators that are further from the boiler they should be adjusted to release more air to compensate for the increased air volume in the piping due to the distance from the boiler. If you have a valve that is clogged with mineral deposits or stuck shut, no air will be able to get out of the piping. Because of this no steam can enter the radiator, so it doesn't heat up. This will block the movement of steam into the radiator, or cause a very noisy hammering as pressurized steam tries to get through this water "dam".
Steam radiators need to have a valve that allows air to escape at a controlled rate so that the radiator can heat up. Steam heating systems will also lose a little bit of water all the time, so there has to be water makeup so that you do not run your boiler dry. Steam heating systems without an automatic water feeder are not safe. You will risk serious boiler damage should boiler water be lost. If the boiler runs dry it could also explode if water is placed into it while it is hot. There should always be a low water cutoff installed on every steam system. Therefore on a steam boiler the automatic water feeder serves as a safety device also.
It is very important that you find someone that is very familiar with steam heating systems when repairing or installing steam heating. Incorrectly designed, installed, steam systems and condensate piping is a huge problem in today's buildings and facilities. There are not many qualified to design and install properly operating steam heating systems. Incorrect steam piping will always cause costly premature failure of steam equipment such as steam coils, heat exchangers, and control valves. Not to mention the higher cost of operating a system that is not working efficiently.
http://www.fixya.com/support/r3904286-steam_system_steam_radiator_air
http://www.fixya.com/support/r4008078-differences_between_steam_hot_water
on Dec 29, 2009 | Heating & Cooling
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
Why is this kettle so noisy
Kettles generally do this, Here's why: As it's heating up, the water next to the element turns to gas and starts to rise to the top. Since the gas bubbles are small at first, they turn back to water before reaching the surface and water rushes in to fill the space - this is what creates the noise. When the element gets quite hot, however, it can convert the water to gas more quickly which creates bigger bubbles that float to the top and burst into the air.
So, the longer it takes to heat up, the longer it makes noise. Some kettles have a more powerful element that simply gets to the second stage more quickly. The 'cordless' ones like yours have a smaller connection from the power to the element and it takes a bit longer. Worthwile, considering the convenience, in my opinion.
Mar 02, 2011 | General (102105011) Electric Kettle
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
Oct 19, 2008 | Oreck Sanapathic DMS2000 Handheld Steam...
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Cleveland Range Cleveland KGL-60 Kettle Logo
Top Cleveland Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cleveland Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
