Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-2192M3 sony tv model display not there but sound perfect
The tv is alomost 15 years old but picture is very blurred but sound is good
2 Suggested Answers
gopakumarg43
  • 74630 Answers
SOURCE: No Display, no sound- not working, showing dead.
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Posted on Nov 27, 2010
Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Oct 10, 2013 | Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
My 15 yo sony tv. model KV-27V55 picture has gone blank and no sound either. Is it worth fixing or trashing?
Cost for repair and the part isn't worth it old chap, especially when the holidays are coming around the corner and retailers are hurting for business.  Why not get a lighter LCD or plasma tele with better 1080 resolution then stress over trying to save this old dog? Off to the heap with it is what I say.
Cheers
Nov 18, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture goes off and on...
Most likely your Cathode Ray Tube or CRT is going bad. That model number reflects an older TV. What you are describing is a fairly common problem for that television. If you bump the TV and it improves or gets worse then you know there may be a short.. Either way, I would recommend that you use our Premium Service or use our online resources to find a repair person near you. Good luck.
Jun 20, 2008 | Sony KV-32V16 TV
No picture only sound
You have to start by verifying the power supply outputs, the scan drive outputs, and the CRT emission.
I would think you have to bring the set in to a service shop to have it properly checked.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture goes on and on constantly
I have the same problem. Picture cuts out completely then back on. When I first turn it on, it does this constantly for about 15-20 mins, then about once every 30 mins or so. The sound is fine, but the picture just flashes on and off.
The color is also starting to shift a lot and cannot be fixed by adjusting COLOR-BRIGHTNESS-PICTURE in the video control menu system. Nothing seems to correct this. I've even unplugged the TV over night to see if it needed some sort of reset. Model = KV-20FV12. Purchased in 2004
My connection is a direct cable connection - Comcast cable. Same problem persist while showing a DVD as well.
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
NO Picture On 2 Video Inputs ( 1 front 1 rear ) : Sound OKAY
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
Dec 13, 2006 | Sony KV-36FS12 36" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
