Question about Vodavi Lands Phones
PHONE ERROR MESSAGE LKD 24D VO.6H SCOUT DX V1.1
PHONE ERROR MESSAGE LKD 24D VO.6H SCOUT DX V1.1 OK SYNC
2 Suggested Answers
slywil091
  • 112 Answers
SOURCE: power surge and now the phone is dead on screen it
take it to the shop for repair,
Posted on Jul 03, 2009
Is Bushnell Scout DX Rangefinder is the good rangefinder?
The Ultimate Bushnell Scout DX Rangefinder
The Bushnell Scout 1000 is a pocket-sized laser rangefinder that offers a 5 - 1000-yard range with a +/- 1-yard precision in 3 diverse targeting modes: Scan, Bullseye, and Brush. The Bushnell Scout DX Rangefinder provides compact and lightweight design along with high-quality visuals to its 5 by 24-millimeter multi-coated optics.
It comes with a hard construction, water resistance, diopter adjustment, roll-down eyecup, a handy tripod mount, and features the ARC method with built-in inclinometer so you can get accurate distance on downhill or uphill shots.
Bushnell claims it will range a deep target at 1,000-yards, trees to 650-yards and a deer at 325-yards. It has a 6x21mm monocular for inspecting and aiming, weight 13.6 ounces and takes up 5.5 x 5 x 3-inches of space. There are a Cardura case, neck strap, and CR2 battery contained in the box along with a cloth to clear the instructions and clean the lens.
The ABS case has adequate non-slip surfaces to help users grip it securely, and there is a tripod hole if you want to have it in a stable position for some time. At this stage of our Bushnell Scout DX Rangefinder review, we will talk about the design of the rangefinder.
The Scout DX 1000 is a smooth and compact equipment that shares a similarity to the high-end G-Force 13000-series from the identical manufacturer. In addition, the best range finder has rubber armoring which provide a smooth and certain grip even when things get wet.
In fact, the Scout is fully water and fog proof which has a massive advantage out in the field. The Scout DX Rangefinder also has a flexible tripod mount that is placed into the bottom of the rangefinder.
Mar 12, 2018 | Bushnell Optics
LG-Nortel LDP-7024D Handset connecting to GDK100
try to check the telephone wire connections. or try to use the other phone box to test.
Sep 09, 2008 | Nortel Lands Phones
Our power went out this morning and now all phones are not working. message on display screen reads LKD-24D VO.6J SCOUT-DX V1.1 NO SYNC
sounds like you have phone service thru the internet. if so, unplug your router for 10 seconds and then plug back in. give it about 5 minutes to reset. This might do the trick?
Dec 07, 2017 | Lands Phones
Power outage kills my Vodavi system. How do I get it to work again?
I am sure you have tried a proper power cycle. Sometimes that will remedy the situation but more often than not you have to reinitialize the mother board and reprogram the system. If reinitialization does not work, then you have to replace the mother board. That is probably why the repair man charges so much.
The best way to protect the system from power surges is to put in a battery backup Uninterpreted Power Supply(UPS). Any brand is fine and the more you pay for one directly effects how long it will operate while on battery backup. If you just need protection from power surges or brown outs a small one should do you just fine. Some brands I am familiar with are APC and Trip-lite. Several brands out there. Make sure you read customer reviews on the one you might purchase. They are very helpful in making a decision.
Vodavi STS are notorious for having an easily corrupted database.I like the STS a lot, but that is my biggest complaint about it. Hope this helps in the future.
Mar 02, 2015 | Vodavi Starplus STSe Universal KSU 3501-01
LKD-24D V0.6J SCOUT-DX V1.1 NO SYNC
If power cycling does not work, the next step would be to reinitlize the phone system. Caution, this will erase all programming and revert back to factory default. I have found over the years that the STSe Database can get corruppted and cause this display read out. If power cycling does not fix it this usu does. If it does not then there is a motherboard issue. Good Luck.
May 27, 2014 | Vodavi Starplus STSe Universal KSU 3501-01
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
Sep 16, 2013 | Lands Phones
Not working at all
Phone isn't programmed as SLT in system
Mar 26, 2009 | Vodavi StarPlus 2706 Corded phone
Lkd-24d error for starplus sts
The technician had to remove the memory module as the board tried to reset itself but the memory module was corrupted and would not allow the board to reset itself. The phone were reprogrammed and are working.
May 12, 2008 | Vodavi StarPlus 2706 Corded phone
Lands Phones Logo
283 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
