Xeror WorkCentre 7428 error code 116 386 while booting
How do I solve wc 7435 error 010-338?
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Xerox WorkCentre 7425 7428 7435 Second...
UI/NC CABLE FAILURE RESET THE MACHINE CODE IN WORKCENTRE 7675
Your error is either a disconnected cable or a bad cable.
Xerox refers to the Operator Panel as the "UI"or User Interface, and the "NC" as the Network Controller. The cable you probably need to check or replace is 117K37660, coming out of the Operator panel back to the copier.
Sep 12, 2014 | Xerox WorkCentre 7665 Copier
004-361 error code in xerox 7345
Hi
Xerox Werk Centre 7428 Tray 2 NVM Read / Write Chain-Linc & Current Value
Feb 03, 2013 | Xerox WorkCentre 7328 Multifunction laser...
LSU Error xeror work centre PE220
if u can hear humming sound during warming up kindly check the wires of laser unit situated in the centre of machine just above toner cartridge but u need to open the whole machine
Jan 17, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Upon booting I get this error, A fault has Occurred. Some features may not be available. No error code to go on...Xerox Workcentre M24 Now were not able to select any functions on the touchpad, and we...
Sounds to me like you need a drum or one of the other routine maintenance items.
The way to find out is to press your machine status button, then look under supplies. You will probably find that a drum life has expired, the IBT cleaning roll or fuser life have expired.
I am sure if you look there one of those "supply" items has reached its end of life.
In the same area under the machine status , there is also a section there for active messages and fault codes. Make sure you look there. If you have additional questions please ask.
If there is an active message or fault code, e-mail me at rak458@aol.com. Just put Xerox M24 in the subject line please.
Feb 24, 2010 | Xerox WorkCentre M-24 Color Copier
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Unable to print to the Xerox m15i with mac OSX
Xeror does not list a Mac driver for this unit. There is a Xerox Global print Driver, which supposedly "drives " all Xeror printers. But again I do not know if it will work on Mac's.There is a phone for this driver support @ 18773626567
http://www.office.xerox.com/latest/SFTBR-15.PDF
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | Xerox WorkCentre M15 All-In-One Laser...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
