Question about Sony KDS-60A3000 60" HDTV
I need a new ballast and the diagram to do so
Wiring diagram for Magnetek hps ballast cat.no.12310-153
All the ballasts I've ever wired have the wiring diagram on the ballast.
I can't find one specific to the Magnetek.
Here's a video -
how to wire ballast 1
Oct 09, 2017 | Garden
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
TV shuts off by itself
I would think a ballast would be easy to change take out old put in new like for like
Nov 07, 2013 | Panasonic PT-43LC14 43" Rear Projection...
I need a replacement ballast and capacitor for a 400W metal halide outside light, I need to know who would carry it and also a wiring diagram
most home depots will have a replacement ballast for this light, inside of box will have the correct wiring diagram, and how to wire it, if not sure as to how to wire it call an electrician
Nov 22, 2011 | Home
I have an ge proline magnetic t12 ballast it has two red leads two blue leads and two yellow where as my fixture has one red one blue and the hot and nuetral are wired through the other side of the bulb...
Need more information, how many lamps are in the fixture? The new ballast is for how many lamps? Basically you need to follow the diagram on the new ballast. If the new ballast is for a four lamp fixture one yellow gets capped and the other yellow goes to one side of each lamp on a two lamp fixture. Then on the other side one set either red or blue goes to the other side of the lamp one wire per lamp and the other set gets capped . Hopefully this helps parkeroc68_0.jpgparkeroc68.jpg
May 22, 2011 | Electrical Supplies
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Oct 27, 2017 | Vacuums
Need wiring diagram for three lamp flouescent fixture using a four lamp electronic ballast
i have a light fixture with two single pin T96 bulbs, black and white wire go to one end of the fixture, two red wires come out of other end - one wire on each socket, but a have a ballast with two blue wires and a red wire coming out the same end of ballast, how do i wire this up? thanks Charlie
Sep 15, 2009 | Kitchen Appliances - Others
Trying to find a ballister circut for a toshiba 62hm95 and is it something that i can replace myself
The Ballast is the correct wording.IT has four
screws and plugs into the lamp.very easy to change.
Sep 04, 2009 | Toshiba 62HM95 62" DLP HDTV
I need change the ballast board on a HD-61FN97
well make sure that first u work in an antistatic area... you can achieve this by hooking the workbench or even urself up to the earth connection in a power socket( THAT IS IF U KNOW WHICH ONE THE EARTH IS) label every connector and cable to the board, draw a diagram if need to... use a NONSTATIC screwdriver to unscrew the board, it should slide out quite easily so this shouldnt be a problem, then take out old board, put in new one connect cables and connectors according to diagram u made, and shove it back in... so yeah not to hard, but antistatic is the key word
Mar 17, 2009 | JVC HD-61FN97 61" Television
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
Sony KDS-60A3000 60" HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
