Question about Whirlpool Dishwashers
What does err2 mean on my whirlpool ADP6000IX dishwasher
My dishwasher is beeping and showing err 2 and it seems to be having trouble draining to.
SOURCE: WHIRLPOOL DISHWASHER ADP6000IX
your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Posted on Aug 20, 2008
SOURCE: problem with whirlpool dishwasher ADP6000IX
Hi I had the same problem with a whirlpool adp6000ix. Although it looked fine from the inside, the base was full of water. I managed to fix the problem by pulling the dishwasher out and then tilting it gently to the side. All of the hidden water in the base poured out which cleared err4. It is now working fine. Tip: Make sure you have a couple of towels spread around before you tilt it. Good luck!
Posted on Jan 02, 2009
SOURCE: WHIRLPOOL DISHWASHER, ERROR CODE 4,
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Posted on Oct 08, 2009
SOURCE: Whirlpool ADP6000WH Fault Code err 2
Hi, i have had my new dishwasher for less than 3 hours and is doing the same thing. Not happy Jan!!!! I have dishes everywhere, stuff out of the sink cupboard and a open house in 2 days. Watch out retravision in the morning!!!!!!! Did you get a solution to yours??
Posted on Jan 13, 2010
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
My whirlpool slimline dishwasher is showing E4 and trips mains when switched on
frothing or water level high. Possible cause using tablets instead of powder or liquid. Take a look at this post.
Whirlpool ADP6000IX dishwasher Kitchen Home
Jan 17, 2015 | Whirlpool Dishwashers
Why would a whirlpool adp6000ix detergent door not open
The dishes/pans you stacked to be washed may have moved and a handle is hugging the bottom drain preventing opening the door. The real main reason is like a car door breaks and it will not open on the outside well the door on dishwasher can break too. When its old then it telling you to update.
Apr 29, 2014 | Dishwashers
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
Hi, We have a fairly new ADP600IX dishwasher. It has stopped mid cycle and is flashing up ERR 4 What does this mean? Many thanks
Error 4 means dishwasher has overfilled with water and is not draining out. This has happened to me twice and I have found turning the dishwasher offf at the powerpoint for at least a week seems to fix the problem.Keep your filter in the bottom of the dishwasher clean.
Mar 28, 2011 | Whirlpool Dishwashers
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
Aug 05, 2010 | Whirlpool Dishwashers
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Jan 01, 2010 | Whirlpool 24 in. DU920PW Built-In...
Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Problem with whirlpool dishwasher ADP6000IX stuck on drain mode has err4 on it which means water inlet problem has sencer that changers to pump mode now is stuck on pump
Aug 07, 2008 | Dishwashers
Dishwashers Logo
27 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
