Question about Xerox Phaser 8500/DN Printer
Xerox phaser 09,035.43:107062 error code
Xerox 8560/DN error code 09,035.43:107062 error code
  • 49 Answers
SOURCE: install wiper on xerox 8560 dn
The user guide is available here http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=8560&Xlang=en_US&Xcntry=USA&prodName=Phaser%208560
Also, I think there are two wiper blades on the 8560, one is on the maintance kit and the other is supposed to be removed, that was the old 860 that could remove theirs. Perhaps cleaning it will be fine. just open the top of the machine and its right there, give it a wipe and it should be fine. The other wiper blade on the maintanance kit and here is a link below to show you how to clean it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=355,E=0000000001343253407,K=1300,Sxi=12,Case=obj(902)
You can use this site to troubleshoot any problems with Xerox printers.
Niallbt
Posted on Mar 30, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Posted on Aug 10, 2010
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
Error message 09,038,46:20728 on xerox phaser 8560
That error states that the ink counter sensor flags are stuck. 9,038 means it is the black one. Make sure there is no blockage in the ink loader and that you are using Genuine Xerox ink sticks. If both of those are fine you need to replace the ink loader. The part # is 133K27711, iteminconline.com has it in stock and can ship same day. Good luck!
Feb 16, 2011 | Xerox Phaser 8500/DN Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Install wiper on xerox 8560 dn
Niallbt
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
