Question about Sony Ps3 Pulse Wireless Headset
Plantronics CS510A keeps cutting out - Sony Ps3 Pulse Wireless Headset
I have a Plantronics 240. It keeps on connecting and disconnecting from my Andriod cell phone
First, you want to make sure there is no interference from other bluetooth apps. Then follow the instructions found on page 4 with the link for the Plantronics Explorer 240.
Good luck from Headsets Direct!
Aug 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics CS55 headset.
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Plantronics CS55 Wireless Headset
We have numerouse CS55 headsets that keep cutting out when speaking on the phone. Choppy sound, missing parts of words etc. Intermittent, will be good for 5 -10 minutes, then bad again.
The first thing to try is resetting the CS55. We hear this a lot and once reset, it usually takes care of the problem. It's equal to a ctrl+alt+del on a computer. Click on the following for detailed instructions and photos:
How to Reset your Plantronics CS55 Wireless Headset
Good Luck from Headsets Direct!
Apr 13, 2011 | Plantronics CS55 Wireless Headset
My headset keeps cutting over to "voice control"
I would suggest resetting the headset and see if that will take care of the problem. Here are the reset instructions: While plugging in the AC charger, hold the power/pair button.
The headphones will show a solid red or blue light when they have been successfully reset.
Below is the link for the Backbeat User's Guide for more information.
Plantronics Backbeat User's Guide
Feb 19, 2011 | Plantronics Backbeat 903 Bluetooth...
I have a Plantronics 210 it periodically stops working.(no blue light) i toss it in a drawer and after a few weeks it just start working again.
Sounds like something is going out internally, could be the battery or a circuit board. Just keep in mind that it has a one year warranty, so Plantronics will replace it for you if it within the warranty period. You can call Plantronics directly at 800-544-4660 ext 5538 or here is a link below for the online warranty service (Quick Web).
Plantronics Replacement Service
Dec 15, 2010 | Plantronics Explorer 330 Headset
Cutting in and out. best described as sounds like i am talking into a fan.
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
Lost my plantronics 222 bluetooth passkey
trying to install my plantronics 222 blue tooth head-set to my nokia 7610,but it keeps asking for a pass code.
Oct 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Jan 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer Plantronics Explorer
That is the job of the ear piece to keep the device in the ear
Jun 19, 2008 | Plantronics Explorer 320 Headset
Sony Ps3 Pulse Wireless Headset Logo
22 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
basssplayer
Level 1 Expert
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
