Question about Garden
How do you change safety switch in the seat of a husqvarna 4623 zero turn?
4 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: How do I bypass my seat safety switch on my
It's not a good idea. But if you must, it's just a switch. If it has two wires, cut them from the switch and connect them together with a wire nut. If it has only one wire, then cut it from the switch, put a spade terminal on it, and connect it to the frame of the tractor.
Posted on Jun 29, 2010
  • 5 Answers
If it is a temp. fix unplug the harness and use a jumper wire across the plugs. This will tell you if the switch is bad preventing the tractor from functioning properly.
Posted on Sep 12, 2010
  • 6468 Answers
SOURCE: husqvarna zth quits when releasing parking brake
check the safety switches on each lever
Posted on Jul 12, 2012
2015-16 Husqvarna zero-turn lawn mower MZT52 will not start up again after engaging the hand brake.
The is a problem with one of the switches in the safety circuit. Either the seat switch or brake switch is bad.
Does the mower start and blades run without the brake? If so, the problem is probably the brake switch itself.
Sep 11, 2017 | Husqvarna Garden
My zero turn Husqvarna mower Starts good, but kills it when parking brake is taken off! Everything is in place otherwise.
You have a safety switch not working. First check your seat switch. Try to engage the PTO with the parking brake on. Blades should start but die when brake is released. My guess, seat switch. Check it is completely connected, these can be hard to connect. Make sure you hear a "click" when the connector is pressed into the switch.
Apr 07, 2017 | Husqvarna Garden
Will not fire, turns over...like no spark
Check to see if there is a safety switch under the seat. This shuts the mower down if the rider falls off for safety. You can test the switch by unplugging it and jump the connections together at the end that is attached to the engine. If it runs in this condition you need a new safety switch in the seat.
Jul 18, 2016 | Husqvarna Mz6128 61" Ztr Lawn Mower Zero...
How to solve problem with releasing brake on zero turn husqvarna the engine dies not seat switch
This sounds like the seat switch. Keep in mind newer model seat switches cannot be jumped or disconnected.
Mar 17, 2015 | Husqvarna Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
When parking brake is moved off position, the engine shuts off on my rz5426 zero turn mower.
One of the safety switches is bad or not making contact. Check the switches on the levers and the seat switch.
Jul 19, 2014 | Husqvarna Rz5426 54" Zero Turn Lawn Mower...
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
When going forward on husquvarna zero turn, my mower shuts off......what could be the problem
First thing to check would be a seat safety switch. There are probably a number of safety switches on your unit and those are easy to test with a multimeter. Using the ohms scale you should have almost no resistance in one position and no reading at all in the other.
Aug 23, 2012 | Husqvarna Zero Turn Mower Z5426
My husqvarna zero turn cuts off when i release the parking brake
safety switch problem-
1. under seat
2. PTO Switch
3. one for handle bars for the drive system
one has either come loose or has failed, most likely one id not fully connected.
Jul 21, 2010 | Husqvarna Zero Turn Mower Z5426
Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Nov 14, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
