Question about Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB 320GB W7P 64BIT W/ P2414H 24IN
Firewire usff 7010 - Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB 320GB W7P 64BIT W/ P2414H 24IN
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
Posted on Apr 07, 2015
My pc wont boot up, led's 3&4 flash, I have renewed the RAM and the fault is still there, does anyone have a clue what the problem is?
Allan Cairnduff,
Below is the information for the 3,4 diag error.
Memory modules are detected, but a memory failure has occurred.
  • If two or more memory modules are installed, remove the modules (see your service manual), then reinstall one module (see your service manual and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error.
  • If available, install working memory of the same type into your computer.
  • The memory specs for this computer are listed below.
  • Type DDR3 Synch DRAM Non-ECC Memory Memory Speed 1333MHz Memory Connectors Four (MT, DT, SFF), Two (USFF) Memory capacities Up to 4GB Minimum Memory 1GB Maximum Memory 16GB(with 1333MHz speed memory)/8GB for uSFF only Memory
    The OptiPlex 790 system supports up to 16 GB of memory in the mini-tower (MT), desktop (DT), and small form factor (SFF) chassis with 64-bit operating system. The maximum memory supported in the ultra-small form factor (USFF) is 8GB. The memory speed supported is 1333MHz DDR3 memory.
    However, 32-bit operating systems can only use maximum 4GB memory address space. Certain components within the computer require address space in the 4GB range, any address space reserved for these components cannot be used by computer memory the amount of memory available to the operating system is less than 4GB.
    NOTE:
    Memory modules should be installed in pairs of matched memory size, speed, and technology. If the memory modules are not installed in matched pairs, the computer will continue to operate, but with a slight reduction in performance.
    NOTE:
    The total amount of available memory will be less than 4GB. The amount less depends on the actual system configuration. To fully utilize 4GB or more of memory requires a 64-bit enabled processor and 64-bit operating system Thank You,
  • Dell-Jesse L
May 15, 2016 | Dell OptiPlex 790 USFF
Firewire port usff 7010
May 07, 2014 | Dell Optiplex 7010 500gb Usff Ultra Small...
How can i reset printer
Hi Ajit,
Please visit this site in order for you to reset your printer. Hope it helps.
Brother DCP 7010 Drum Unit Reset Instructions
May 06, 2014 | Brother DCP 7010 Multifunction Laser...
How to download pictures from my olympus stylus 7010 to my computor
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such a Picasa ( http://picasa.google.com ).
Apr 12, 2014 | Olympus Stylus 7010 Digital Camera
Hold shutter open on a olympus 7010 for night shoots
One of the biggest disadvantages of a point&shoot camera is that they expect you to point and shoot without having to bother with minor details like shutter speeds and apertures. The 7010 is no different, offering no way of controlling the shutter speed directly. The best you can do is to set either the Night Scene or Night Landscape mode.
May 14, 2012 | Olympus Stylus 7010 Digital Camera
No view of Olympus 7010 screen after dropping
You'll have to take the camera in for service to replace the component that was damaged in the fall.
Unfortunately, the cost to repair the camera will most likely be as much or more than just buying a new, replacement camera.
Feb 13, 2012 | Olympus Stylus 7010 µ 7010 Digital Camera
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
Olympus 7010 shuts down in picture mode - not a battery problem
I will tell you how I did it for the same price you were going to charge me for a solution. To ask how I did it once I found a solution without a fee goes against your business model.
Dec 28, 2009 | Olympus Stylus 7010 Digital Camera
DCP 7010 How to install without CD
you didnt mention what your operating system is but go here this should help..... http://www.soft32.com/download_181357.html
Jun 17, 2009 | Brother DCP 7010 Multifunction Laser...
How to install scanner of brother dcp 7010?
The move the software completely. Shut down the computer. Unplug the device. Get offline and disable the A/V program. Now reinstall and do exactly what the prompts say- no short cuts.
Jul 10, 2007 | Brother DCP 7010 Multifunction Laser...
Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB 320GB W7P 64BIT W/ P2414H 24IN Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
