Question about Sierra Overdrive Pro 3g/4g Mobile Hotspot For Virgin Mobile
Virgin mobile my account
Need activate the device: having trouble activating
  • Bradley Wales May 28, 2014
    Hi Elenilson Sorto, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Why can't I activate my phone to my account ?
Really need more info. Maybe it is locked for use only with a different supplier? Have you paid Credit? Is it a new phone or used?
Nov 14, 2015 | Samsung Montage Virgin Mobile
I bought a virgin mobile top up card for $15.00. How do I activate my existing virgin phone?
If you allowed the phone to "expire", then contact customer service and they will reactivate your number and even add in the $15 worth of minutes to your account for you.
Sep 03, 2015 | Cell Phones
Want to activate virgin phone
YOU CAN CONTACT VIRGIN MOBILE (1-888-322-1122) AND THEY CAN ASSIST YOU WITH THE ACTIVATION. WHEN YOU CALL, HAVE THE PHONE OFF AND REMOVE THE BATTERY, YOU MAY NEED TO READ THE NUMBERS LOCATED UNDER WHERE THE BATTERY SITS.
Jul 17, 2014 | LG Optimus V For Virgin Mobile
Can not activate phone
Double check what you have input make sure it's correct and has no leading or ending spaces(this happens alot if you copy from on place and paste into a browser sometimes it put's a leading or ending space. If everything's correct call Virgin Mobile's Customer service.
Nov 13, 2013 | Virgin Mobile PCD Venture No-Contract...
How do i flash a sprint galaxy s3 to virgin mobile?
no way of activating or using non virgin mobile phone on virgin mobile..flashed nor unlocked..need to purchase a virginmobile phone to get service..cal 1-800-322-1122
Oct 20, 2013 | Samsung Galaxy S Iii Sph-l710 - 16gb -...
Virgin Mobile Overdrive 3G/4G Pro won used on eBay and cannot activate.
They are correct. You will need to replace the SIM card.
May 27, 2013 | Computers & Internet
When i insert a virgin sim card in a virgin network phone it does not work!
Thanks for visiting FixYa!
Virgin Mobile uses proprietary software in it's phones. As such, (depending on the phone) a SIM card already activated for one Virgin Mobile phone may not work in another (different) Virgin Mobile phone - even if it is the exact make and model.
You may need to contact Virgin Mobile Customer service to request a new phone added to your account - and they may need to provide you with a new SIM card. They'll be able to let you know what you'll need to do depending on which phone you want to use on your account.
Mar 24, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
The top up code on the virgin mobile card won't activate my phone what do i do?
you have to get a seperate phone and call customer service and set it up. Or go online @ virginmobileusa.com and activate.
If you would, send me a kickback! :D
email: jvandiver@boysranchisd.org
Kickback code: hTvsPJQD
Hope it Helps!
Jan 11, 2010 | Alcatel Virgin Mobile ?£30 Text Cellular...
Samsung virgin mobile pay as you go cell
You need to have the phone activated again through your service provider.
Jun 22, 2009 | Samsung Cell Phones
Mxit v 5.6
PHONE SUPPORT
Some phones are not compatible with the MXit application. Don't stress, yours is most probably supported. If you want to double check however, simply click on the relevant link to the left:
(Do not know your mobile make? Have a look its battery, it's usually written there!)
We are constantly expanding our service; if you could not find your phone on this list, don't worry, it is likely to be added soon...
DOWNLOAD
Downloading MXit from our WAP-site:
Jargon buster: A WAP-site is an internet website customized to be viewed on your phone.
  1. On your mobile, go to 'services' (globe icon).
  2. Create a new bookmark (www.mxit.com/wap) and save it.
  3. Select this bookmark, then select then 'go to'.
  4. You should be welcomed to the MXit WAP portal at this stage.
  5. Check that your mobile manufacturer and model has been detected correctly.
  6. Open, accept and download!
  7. Start chatting
CONNECTIVITY
Setting up GPRS/3G
Get connected via your service provider's service menu; just follow the simple instructions below:
(It helps to know your mobile's manufacturer and model. Oh and remember, you only have 2 minutes to complete these steps, don't ask us why!)
Vodacom:
  1. On your mobile, dial *111#
  2. Select option 5 (phone settings) from the menu that follows. (Answer -> 5 -> send)
  3. Select option 1 to choose your mobile make and model from a list, or options 2 to have Vodacom identify the phone for you.
  4. In both cases, simply follow the steps provided to get the WAP settings sent to your phone.
  5. Connection settings will be sent to your phone; save these settings.
  6. If any of the above mentioned steps fail, simply retry.
  7. Still having trouble? Call Vodacom's call centre on 111 from your Vodacom cellphone or 082 111 from another phone. Alternatively visit a Vodacom outlet near you.
(GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Cell C
  1. On your mobile, dial *147#
  2. Connection settings will be sent to your phone; save these settings. If a password is requested enter 0000
  3. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call Cell C's call centre on 140 or visit a Cell C outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
MTN
  1. On your mobile, dial *123#
  2. Select option 1 (phone setup) from the menu that follows. (Answer -> 1 -> send)
  3. Select option 3 (WAP).
  4. Connection settings will be sent to your phone; save these settings.
  5. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call MTN's call centre; dial 808 (contract) or 173 (pay as you go) from your mobile phone. Alternatively, visit an MTN outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Virgin Mobile
  1. When you first insert your Virgin Mobile SIM into your mobile you'll receive an SMS asking you if you would like to accept Virgin Settings.
  2. If you reply YES, your settings for MMS and WAP can be automatically downloaded and installed on your mobile.
  3. Do the following to manually request MMS and WAP settings:
  4. Go to the 'Virgin Mobile' menu which you will find on either the main menu or applications menu of your mobile.
  5. Select 'Virgin Settings' and reply YES when asked if you'd like to download them.
Still having trouble? Call Virgin Mobile's call centre on 123 or visit a Virgin Mobile outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Apr 04, 2008 | Samsung SGH-E370 Cellular Phone
Sierra Overdrive Pro 3g/4g Mobile Hotspot For Virgin Mobile Logo
77 people viewed this question
Top Sierra Computers & Internet Experts
Glenn
Glenn
Jacqueline
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
