Question about PfaFF Sewing Machines
Tamato overlock 5 stitch will not catch
The 5th needle is not sewing the fabric.
    Novelist:
  • 268 Answers
Typically this is a threading or damaged needle or incorrect needle problem. Sometimes a timing or alignment problem.
Posted on Jun 12, 2014
3 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: My janome 9200D overlocker has stopped sewing.
it's possible that the machine has gone out of time & needs to be serviced
Posted on May 30, 2012
My overlocker is skipping stitches, I have re threaded it and replaced the needles and oiled it, it is still skipping stitches. any ideas as there is nothing else in the manual to tell me what to do>
Check to make sure you have the right needles and that the thread and needles are compatible. Usually, coverstitch machines use a slightly longer needle than overlockers and sometimes people get them confused. Also, it might have something to do with the fabric you are overlocking. Try stitching a different kind of fabric and see if it is still a problem.
Mar 09, 2015 | Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
Hand held sewing machine
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Sewing Machine Needle Not Catching Thread
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Sewing Machine Anatomy How Stitch is Made
Jan 18, 2018 | Sewing Machines
May 29, 2012 | Sewing Machines
What are the settings for overlocking stretch fabrics
For knits with lycra in, you are best to thread up four threads and seam with the 4 thread marrowing stitch like this, preferabbly with ball point needles in your overlocker, size 80. Use cones of polyester thread, 3,000 metres or 5,000 metres rather than normal thread. (Although if you have trouble matching thread colours you can use a small reel on the left needle as this is the thread that will show on the right side of the garment.)
Start with your machine tensions on 5, both needles in and threaded, stitch length of 2.5 and no differential (set it on zero) and test stitch. Using stretch or ballpoint needles is a good idea too to avoid any deflection and skipped stitches. Then practice serging on some fabric scraps, double layer and look at the seam, if it is tunnelling (pulling up the fabric), then move the cutting blade to the left. Test again and if still tunnelling, then loosen off the tension on the top and bottom loopers by a half number and test again.
If the opposite is happening and the threads are looping off the edge of the fabric, then move the cutting blade to the right to trim less fabric, test again. If still too loose, then tighten up the top and bottom looper tensions by a small amount and test again.
You want the seam to lie flat, the two looper threads to meet right on the cut edge and the needle thread to be just visible from the right side when you press open the seam.
There is always a small amount of adjustments needed on an overlocker when setting up for a new project as every fabric will behave differently. Don't tighten up the tension on the needles much past 5 though, or you may get thread breakage.
If you find that the seam is flutting then you can use the differential feed to adjust for this too.
There is some good overlocking info on Debbie Cosgroves website, www.sewing.about.com, with images which may help too.
Nov 07, 2011 | Janome MyLock 634D Mechanical Sewing...
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
How to use a blind hem stitch foot on the White overlock 2000
The blind hem stitch foot is actually just a guide to keep the folded edge of the fabric away from the cutters, and close enough to the needle, to catch a snippit of fabric to actually hem the item you are feeding thru the machine.
The trick is in the folding, and this vid clip is a good guide for the folding technique. Keep in mind that the 'lip' of fabric she is talking about will be overlocked, and your hem will have alot more 'give', providing a stretch that would be helpful for a stretch fabric.
http://www.ehow.com/video_4407404_machine-sew-blind-hem.html
Mar 16, 2010 | White Sewing Speedylock 1600 Mechanical...
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Babylock Eclipse SX won't catch the overlock stitch
  • the factory default settings are 4,4,4,4 and M
  • Change the needles
  • use a can of air spray ( compressed air can sold in computer stores) to ensure there is no fabric or dust under the needle plate
Jun 28, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
16 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
