Question about Frigidaire Freezers
Frost Free Frigidaire Freezer is frosting and leaking water
I have a Frigidaire upright freezer Modle # lffh2067dwz Serial # wb63339990 that is forming frost around the door and food. It is also leaking water into the floor. The temp has stayed at freezing and food is solid. What should I do?
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
aasc
  • 1606 Answers
SOURCE: frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Posted on Jul 07, 2009
  • 358 Answers
SOURCE: My upright freezer won't self defrost. Frost builds up right awa
Probably (90% of the times) the defrost timer is bad and has to be replaced.
Posted on Sep 19, 2009
  • 121 Answers
SOURCE: Temperature alarm is on on
i would make sure that the coils are all clean, inside and out. make sure the fan runs on the back, the water pan isn't over flowing.
Posted on Jun 25, 2010
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost build up Frigidaire FFHS2611LSO
Frost build up usually indicates an air leak - check your door seals and any part of the door for gaps. Also make sure the unit does not need to perform a defrost cycle.
Aug 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
267 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
