Question about Samsung Washing Machines
Wa80v3 Why does the machine vibrate
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Where to find WA80V3 control panel
Even if you do replace the panel you still need to get rid of the cockroaches because it will keep on happening. Since the panel may be hard to find I see no other alternative then to replace it with what they suggest. I see no other option except for getting rid of your washing machine and buying a new one, so for the $60 they want to fix it seems well worth it.
Good luck,
Marty
Jul 15, 2014 | Samsung CASE-DETERGENT;WA80V3 -...
Samsung wa80v3 does not drain water
check the drain pump isnt blocked. there is a panel at the bottom front of the machine. remove this and unscrew the round cap and look for a jam. turn off machine first! move the propellers with you fingers. if its ok it should turn a quart of a turn then race forward some
May 17, 2014 | Washing Machines
Samsung automatic WA80V3 does not drain water
the pump maybe jammed or the filter could be blocked.
if you need advise on how to check, let me know
Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Nov 28, 2012 | Washing Machines
Washing Machines Logo
10 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
