Question about Blaupunkt BT Drive Free 112 - Visor Mount Bluetooth Speakerphone
I have a 112 bluetooth device and it is paired but I do not understand if I also need the 2 blue ticks against the phone and media? Without these ticks is the device not properly connected and why will it sometime connect fully and have the blue ticks but 99% of the time it will not despite re-booting both devices several times! Sometime it the 2 blue ticks or even one blue tick are visible they disappear within minutes! Please can someone explain what the ble ticks are and if they need to be visible! Since purchasing the device I still have to make do with the loud speaker function on my mobile as the bluetooth device never works even though it is definitely paired and shows it is connected and paired!
I have two bluetooth enabled phones that I would like to get paired. The first one is a Samsung Galaxy Tab and the other is Nokia 2630. I would like to use the SGT's A2DP / Call and have the Nokia on...
Sure! If your headset has never been paired to another device before, just by turning it on, it should enter the pairing mode, denoted by its indicator light steadily lit in blue. Otherwise, starting with it turned off, press and hold the answer/end key some seconds beyond the point to turn it on. Release the key only when you notice the indicator light steadily lit in blue. Now, first on your Galaxy Tab, go to 'Menu > Settings > Wireless & network > Bluetooth settings' and tick the 'Bluetooth' checkbox to turn it on. Then, tap 'Scan devices'. After a little while, your headset should appear in the list of paired devices. If needed, slide your finger to find your headset in that list. Tap it to start the pairing process. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You will be prompted to choose the bluetooth services you want, i.e. phone and media. Of course you can come back to these settings whenever you want, in order to activate or deactive these services. Now untick the 'Bluetooth' checkbox to turn it off, in order to pair your headset with your Nokia phone.
Then, turn your headset off and press and hold the answer/end button to put it in paring mode again. Now, on your Nokia, go to 'Menu > Settings > Connectivity > Bluetooth' and select 'Bluetooth > On'. Then, select 'Search for audio enhancements'. After a while, your headset should appear. Select it and make it connect. Again, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zenros).
Your headset will be able to handle both your Galaxy tab and your Nokia phone at the same time. it is already connected to your Nokia phone. Go back to your Galaxy tab, and tick the 'Bluetooth' checkbox again to turn it on. You should see the bluetooth icon light in blue in the notification area.
By the way, your headset's user guide can be found here, your Galaxy Tab's here, and your Nokia phone's here.
Hope you are able to sort your problems out soon.]
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Apr 02, 2011 | Jabra BT3030 Wireless Headset
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Oct 31, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Blaupunkt BT Drive Free 112 - Visor Mount Bluetooth Speakerphone Logo
177 people viewed this question
Top Blaupunkt Radio Communications Experts
eradiostore
eradiostore
Are you a Blaupunkt Radio Communication Expert? Answer questions, earn points and help others
