Question about Sewing Machines
LOADING BOBBIN 4832C SINGER ELECTRONIC CONTROL
4 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Singer 9015 sewing machine - bobbin loading
bobbin goes under the door of the needal, the thead come out from the right to the left, thead goes in the first edge and up and out of the left, you need the needal to be treaded, turn the round right know till the needal goes in and out , pull the tread up and out together.
Posted on Nov 26, 2007
  • 323 Answers
SOURCE: model 4832c
guide the the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)If it doesn't work like this, then there is probably thread stuck inside the tension assembly. Set the tension to zero and blow hard between the discs to dislodge the thread. If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
Check to be sure you have the correct bobbin and that it is inserted the correct way.
OR remove the needle plate to remove the bobbin case. Look for any burrs or rough spots. Use a fine emery stick and steel wool to remove and buff them Reassemble and try again.
Sewman7
Posted on Jun 18, 2008
SOURCE: Hi - I'm in the market for a sewing machine. I'm
I used to sell necchi's, I have used necchi's for over 30 years for sewing & quiting. I own a necchi model 4595 mechanical sewing machine, & a omega by necchi, model 6150, electronic, my husband does his quiting on it.I have made clothes & quits on both machines
I have never sold or tried a necchi 3205fa or a singer 4832c
all I ever had were old singers, which I have gotten rid of all them
make sure it has a operation manual with it.
make sure you can take it back if something is wrong with it.
happy sewing
Posted on Jul 30, 2010
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
Install bobbin case
Watch in utube for 'singer front loading bobbin case' and other links that can be helpful to you.
Nov 07, 2013 | Singer 8280 Mechanical Sewing Machine
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
Hi - I'm in the market for a sewing machine. I'm trying to decide between a Singer 4832C or a Necchi 3205FA. Which would u recommend? Thx.
happy sewing
Jul 23, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
