Question about Radio Communications
Life expecancy motorola cp040 - Radio Communications
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Posted on Aug 12, 2009
eradiostore
  • 1654 Answers
SOURCE: question about motorola cp040
The CP040 is a sister to the US version CP200. These features (roger beep and Tx power) are done during the programming of the radio using Motorola CPS software, a radio interface box (RIB) and appropriate cable. The software is proprietary to Motorola and is available by subscription to Authorized Motorola dealers and other qualifying entities. You can stop by your local Motorola shop to have the radio reprogrammed. (approx. $15-25 US)
Posted on Jan 28, 2010
SOURCE: I need the software for programming Motorola CP040
HELLO I GET A CP040 BUT HOW TO RESET IT FOR NEWS FRENQUENCE
Posted on Sep 04, 2010
I am wanting to programme Motorola cp040 radios what software can I use
Motorola factory software, with a factory cable. You need an FCC License. Take them to a dealer if you do not want to spend a few hundred dollars. No, there are no pirate copies available. Hope this helps.
Apr 30, 2016 | Motorola Radio Communications
Acoustic tube adaptor kit
There are a variety of earpieces available for this style radio. The clear acousitc tube style is common when used for surveillance or in covert operations. If you are not needing it for this purpose you can get a more durable earpiece with a black or tan wire leading to the ear.
Best regards.
Apr 23, 2013 | Motorola Radio Communications
Motorola cp040 problems
To be able to give you the right advice, we need more info.
What is the nature of the problem?
are you trying to repair or replace the charger?
Unless we have this info, we're only guessing, which is totally useless to you.
Please reply with the info we require and we'll direct you to the answers you require.
Cheers,
Peter
Feb 03, 2013 | Universal Motorola CP040 Rapid Six-Bay...
Why would a daily recharge be needed?
Because it isn't made of the best battery cells,there may be some memory effect with it.Get more tips for prolong battery life.
Apr 16, 2010 | Motorola Mobility BT50 Cellphone Battery
Question about motorola cp040
Jan 27, 2010 | Radio Communications
I need the software for programming Motorola CP040. Can you help me ?
Jan 13, 2010 | Motorola Radio Communications
Aug 12, 2009 | Motorola Radio Communications
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
