Question about Bosch Water Heaters
Where can i download the manual for a thermor water heater?
Model number 221076 no manual
2 Suggested Answers
  • 32 Answers
SOURCE: where can i download a installation manual for a thermor water heater code number 221076?
Hot water heaters boilers THERMOR Premium PRO 15 OPRO15 221076 boiler
Run it through Bing transulator and you will se a link at the bottom that says installation.
Posted on May 07, 2014
Testimonial: "Good thank you."
Where can i download the manual for a thermor water heater"?"
www.reliancewaterheaters.com/lit/spec/2006ServiceHandbook.pdf
May 07, 2014 | Reliance Water Heaters
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
We have a 2006 31 ft fleetwood prowler trailer. We can't find in manual switch for water heater. We see the switch with electric and gas on wall but which symbol is "on" &...
I do not have specific answer.
Open following links to identify product, download service guide and download manual for the different model numbers, plus parts list and other resources:
Page 3-4 of following manual shows switch settings for LP gas.
On-line manual can be word-searched for 'switch.'
This water heater has remote switch, which is the switch you are talking about. It also has limit switch and ECO (energy cut-off switch)
http://waterheatertimer.org/pdf/Atwood-installation-maintenance.pdf
http://waterheatertimer.org/pdf/Atwood-Water-Heater-Service-manual.pdf
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jul 26, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
http://waterheatertimer.org/How-to-install-gas-water-heater.html
May 01, 2011 | Whirlpool Water Heaters
I have a GP series LP 50 gal water heater. The "ON" valve appears intermittent. As I rotate the valve after the pilot is lit, the burner is quiet and low in one position and noisy with a high...
You posted under Rheem gas water heater.
GP can be gallons-per-minute
I believe you have tank-type gas water heater from description of gas valve:
Information is on label on side of tank showing Brand, type, BTUs, model number, and serial number.
Gas valve information is located on side of gas valve:
http://waterheatertimer.org/images/04128.jpg
Since water heaters vary widely, the best place to start troubleshooting is manual for your specific model.
Open following link to identify product. Click on water heater that looks like yours, and next page has pdf files where you can download install-operation manual.
Search pdf for the word 'ON' or 'gas control'
In any case the manual should be digested fully to gain understanding of your specific water heater.
Once you identify product, re-post question on fixya or the tank, with link to manual, to see if more information can be gleaned from experts and professionals
Also post a photo of your gas valve for possible identification by expert:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Find age of water heater using serial number
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
If you have Rheem tankless: open following link:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 14, 2011 | Rheem Water Heaters
OUTSIDE GAS MODEL NUMBER c85, WATER IS NOT HOT TAN...
I have two C85 Rinnai and one is turned off because it leaked... the other one does not heat water... I have it set on 120.
Where can I download a repair manual on these? I am in Nicaragua and dealer wants to replace them or something.
May 20, 2010 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
