Question about Speed Queen AWS75NW Top Load Washer
Tighten belt on motor? - Speed Queen AWS75NW Top Load Washer
Why doesn't the needle go down?
1. If the machine motor is running you can see if the bobbin winder is functioning. If so then you need to tighten the hand wheel lock.
2. If it doesn't work try loosening the screw on the hand wheel lock. 3. Try to tighten the wheel lock now.
4. Now, tighten the screw.
5. If it still isn't functioning you may need to loosen the motor and replace the belt.
6. Belt. Remove old belt. Put new one on while motor is loose. Tighten the motor while you keep the machine running at a slow speed. As you tighten the motor there will be a point the motor speed rises the most. Tighten the motor there and recheck afterwards.
Mar 20, 2015 | Sewing Machines
Tip
When the walking belt is slipping during use.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
on May 01, 2010 | Exercise & Fitness
Belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
Belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
Belt & motor stops
Apr 14, 2009 | Exercise & Fitness
My treadmil is slipping and I can not find an online manual.
Apr 04, 2009 | Exercise & Fitness
Belt stops as soon as any weight is applied.
Apr 03, 2009 | Proform 560hr Treadmill Walking Belt
Motor is running but belt isnt moving
Mar 31, 2009 | Proform 650 Crosstrainer Treadmill
What do i do when the belt skips while u are on it?
Jan 12, 2009 | Endurance TF3i Folding Treadmill
Speed Queen AWS75NW Top Load Washer Logo
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
