Reprogram remote for coonara grange royal gas heater
2 Suggested Answers
  • 4736 Answers
SOURCE: can i use a universal remote on a gas heater
If the universal remote is compatible with a milllivolt gas control valve receiver or it comes with a millivolt receiver that can be wired into the heater, then it should work. If it doesn't do or have any of the aforementioned, then, no it probably won't work. The hand held remote and the receiver frequency have to match or be capable of being reprogrammed.
Hope this helped to answer your question.
Posted on Apr 22, 2011
I need a new door or just replace glass. I have a coonara fire heater any suggestions
the glass will be heat resistant pyrex glass so unless you can get the glass heat treated , get a new door
May 06, 2017 | Ovens
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
I need to put a new baffle plate in my 2100 coonara wood heater and cant find anything on internet bout how to do it
Try MFG website, or email their customer service. Also try the replacement part via Ebay. May have instructions with the plate.or do you already have the plate? If so go back to the seller and ask for the install instructions. (usually they come with the part)
Jun 13, 2015 | Cars & Trucks
Hi. I have 2002 grang cherokee 2,7 T diesel. when I use my remote key all is open but no driver door.but alarm is still armed , when I open the doors alarm sounds exept driver doors . When i turn the...
try this first, make sure all doors are locked. Insert door key in drivers side door lock and turn key left for 3-5 seconds then turn to the right with a little pressure. open door. Insert key in ignition and turn to on ONLY! wait at least 30 seconds, then turn key to start allow to idle for a few minutes. If problem persists, the remote is not functioning properly. contact a locksmith for reprogramming or replacement. A lock shop will be cheaper than the dealer! Hope this helps you!
Dec 28, 2014 | 2002 Jeep Grand Cherokee
I have a rinnai flame fire inbuilt royale 1b35etr but not igniting . what do i do. electrics come on and no smell of gas- pipes all look good and gas bottle on
First, be sure that the inline gas shut off valve is turned ON. The gas tank valve is On, but the inline valve may not be. if you do find that the inline gas gas shut off valve is ON, there may be air in the gas line that needs to purged.
In case you have your Owner's Manual, I have included a link to it, that you can download & print for future reference. it will explain how to purge the line, if necessary.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Flames/Royale%20Inbuilt.pdf
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa. Cheers.
Aug 16, 2011 | Heating & Cooling
Hi i have a Rinnia Royale ETR heater and every time i run my gas hot water the heater goes out. It seems as if there is not enough gas to run both at the same time.can you help. thanks Brian
Definitely sounds like there is a gas pressure problem. Are the gas lines feeding both appliances the proper size (at least 1/2" diameter)? Are they natural gas or propane units. If propane, what's the Btu rating of the regulator on the propane tank? If it's to low to handle the two appliance at one time, that could be the problem too.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/
Can i use a universal remote on a gas heater Coonara Grange? Unit was a in store demo and remote was missing A new one is $300
Apr 22, 2011 | Universal Remote Control Heating & Cooling
WHAT SIZE HOLE IN JET ON HOT WATER HEATER TO CHANGE FROM NATURAL GAS TO LP GAS
That doesnt work with these units they are manufactured gas specific. The manifold plate would need to be changed as well as notification to Noritz to have a new serial # issued. PC board reprogram required, etc. Buy a natural gas or LP model.
Apr 27, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Glow plug comes on bright orange but does not ignite gas.
If the bake igniter glows bright grange and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Oct 05, 2009 | Maytag CWG3100A Gas Single Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
