Question about Dayton Gas Furnace Heater
Reprogram remote for coonara grange royal - Dayton Gas Furnace Heater
I need a new door or just replace glass. I have a coonara fire heater any suggestions
the glass will be heat resistant pyrex glass so unless you can get the glass heat treated , get a new door
May 06, 2017 | Ovens
Hi. I have 2002 grang cherokee 2,7 T diesel. when I use my remote key all is open but no driver door.but alarm is still armed , when I open the doors alarm sounds exept driver doors . When i turn the...
try this first, make sure all doors are locked. Insert door key in drivers side door lock and turn key left for 3-5 seconds then turn to the right with a little pressure. open door. Insert key in ignition and turn to on ONLY! wait at least 30 seconds, then turn key to start allow to idle for a few minutes. If problem persists, the remote is not functioning properly. contact a locksmith for reprogramming or replacement. A lock shop will be cheaper than the dealer! Hope this helps you!
Dec 28, 2014 | 2002 Jeep Grand Cherokee
Can i use a universal remote on a gas heater Coonara Grange? Unit was a in store demo and remote was missing A new one is $300
If the universal remote is compatible with a milllivolt gas control valve receiver or it comes with a millivolt receiver that can be wired into the heater, then it should work. If it doesn't do or have any of the aforementioned, then, no it probably won't work. The hand held remote and the receiver frequency have to match or be capable of being reprogrammed.
Hope this helped to answer your question.
Apr 22, 2011 | Universal Remote Control Heating & Cooling
We purchased this model used and were wanting to know how to reprogram...set the date, taxes, time and basic functions. We are not wanting to set up dept. if it has this capability. Just cash, check and...
You probably know that the website doesn't have the manual link yet. So your best bet is to have a look at a manual for other models.
Royal 110cx
http://office-zone.com/manuals/royalcash.pdf
Royal 130cx
http://www.devicemanuals.com/guide/Cash%20Registers/Royal/Royal-130cx-Cash-Register-manual-==TVRRM016UTU=.html
Aug 26, 2010 | Computers & Internet
Need building instructions for a sunncamp grange tent or pictures
This is as close as I could get. It's the instructions from Sunncamp itself, so I'm guessing they're the instructions that come with the tent, too.
http://www.sunncamp.co.uk/assets/pdfs/instructional/Grange.jpg
Hope this helps. =)
Oct 10, 2009 | MSR Family Tents
Remote keeps making low battery sound on two way.
We run into this a whole bunch at my shop. Take it back where you bought it and tell the shop about the battery drain. Those remotes had a problem and DEI has corrected the problem and you should have no problem trading in the remotes for new ones. It was a royal pain in the *** for me and i hounded DEI. I was told it was some loose solder on the board that caused the problem. hey, good luck and let me know if you have any problems. mark
Aug 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My royal cms487 plus cash register keeps malfunctioning after I reprogram it. I have the manual and follow the instructions, but it won't always allow me to do a full system clear. When it does allow it I...
Unplug register, put in program mode, hold down C key and plug in register while holding. Now you can turn key register mode. This should clear it. I just read it on another site and it worked for me!
Mar 04, 2009 | Royal X3 Calculator
Need to change local tax on my royal 120rx cms
Hi.
Royal are a very small company, so it is difficult to get information.
You could try the models on their site and see if one of those has a similar tax setup:
http://www.royal.com/drivers_manuals.htm
Otherwise, you may have to see a dealer.
Mark
Feb 12, 2009 | Casio Parts Cash Register PC Desktop
Dayton Gas Furnace Heater Logo
16 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
