Question about LG Televison & Video
47lg70yd wont turn on, standby light pulses red on turn on, but then goes a faint blue colour, no display on screen. yet when pressing the remote buttons, the faint blue light flashes with key press.
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
SOURCE: flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Posted on May 22, 2008
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
  • 10 Answers
SOURCE: t.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Posted on Sep 01, 2009
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Screen black
Here's the test to determine which board is faulty. With the TV on, as usual, shine a flashlight on the screen to see if there is a faint picture. If there is, then the ballast board for the backlights is bad. If there is no visible picture, then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 13, 2017 | Hitachi P50H401 50 in. Plasma HDTV
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a new 42"
I'd tell you how to repair it, but it'd void your warranty, and I never advise anyone to void their warranty, so I suggest you take it back and get it fixed or replaced under warranty.
Cheers!
Mar 15, 2011 | Televison & Video
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
My Accoustic Solutions HDTV, Model LCD37761HDF is only going from red to blue to green screens. When the on button is pressed it is supposed to go into standby but it just goes into the loop described...
YOUR POWER SUPPLY IN TV SPIKED AND CORRUPTED 24C64 EPROM RESULTING IN 4 PRIMARY COLOURS DISPLAYED NEEDS REPLACEMENT PREPROGRAMED 24C64 EPROM.
AVERAGE REPAIR COST £59+
Aug 25, 2010 | Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
Sony KV 25 F3U
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Sep 16, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
Computer Repairing
Computer Repairing
