Question about Canon Image Runner 1630 Copier Copier
Ir finisher 2870
Ir 2870 finiser jam
3 Suggested Answers
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
  • 990 Answers
SOURCE: Canon IR 2870 A3 printout tail crumpled
Hello sir; When you print A-3 size paper did you set up on computer for a-3 size paper, most case A-3 size use in europe, usa use letter size. I hope that's the problem,
Posted on Jan 29, 2010
IR 2870. How do I clear paper jam in fixing unit?
hi. if you already remove the jammed paper the copier machine should work fine if jam persist there is a faulty flag sensor
Nov 26, 2015 | Canon Office Equipment & Supplies
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How to reset finisher canon2870
What is the problem???? Please explain in Detail the problem!!!!
Can't give you an answer if don't know the problem.
Dec 19, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
Canon Image Runner 1630 Copier Copier Logo
20 people viewed this question
old marine
old marine
