Question about Kenmore Refrigerators
MODEL 106.53384300 COMPRESSOR CLICKING NOISE NOT COOLING
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
  • 108 Answers
SOURCE: Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Posted on Oct 19, 2008
  • 159 Answers
SOURCE: frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
Posted on May 16, 2009
aasc
  • 1606 Answers
SOURCE: have a whirlpool refigerator. Model ET8BPKXKZOO.
The overload/relay which pluggs onto the side of the compressor is bad . Pt # 2262181
Posted on Aug 07, 2009
  • 1218 Answers
SOURCE: my kenmore sidexside quit cooling and freezing.
Good day,
He can't, although it's a good guess. However, The compressor can be tested and run with a special test cord most all techs have.
It allows the compressor to be run independent of the rest of the machine and is the definitive test. I would not go forward unless that test is performed. Compressors are too expensive.
Posted on May 12, 2010
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
GE Profile - model PDS20SBSALSS - constant clicking noise
The clicking is the compressor trying to start. If the compressor is extremely hot, try allowing it to cool. The condenser fan should run even if the compressor is out on overload; that may be the cause of the compressor failure. Check the supply to the fan and replace it if it doesn't run.If the compressor has been overheating for some time, it may be damaged and also need replacing.
Jun 13, 2012 | GE Refrigerators
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
KENMORE MODEL 106.53532300 SIDE BY SIDE WILL NOT FREEZE OR COOL. FANS RUN, BUT A CLICKING NOISE INSTEAD OF COMPRESSOR RUNNING, COMPRESSOR IS VERY HOT. WHAT SHOULD WE DO?
its most likly the start run relay . this plugs onto the side of the compressor and changes it from start to run . these models seem to have this problem in this age range call sears you can get a relay put it on your self not terribly expensive
Jul 04, 2011 | Refrigerators
My Maytag refrigerator Model # MSD2651HEW (26 cu ft , side by side) would not cool there was a rrrrrr noise with a clicking noise and the compressor would heat. I got a factory OEM part from Sears and...
Did you lay down the fridge while cleaning it? if so: Normally if you lay down your fridge the compressor oil is running into the pipes that carries the gas to cool the inside. if that oil is in the pipes you have to shut it down for at least 2 days for the oil to return to the compressor, if not layed down, the chances are that you running out of gas and had to have it refilled
Dec 11, 2010 | Maytag MSD2651 HE Side by Side...
GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 09, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
Side By Side refrigerator ED5PHEXMQ00 Model #_ Click
The clicking noise may be the overload located at the compressor. If so the compressor start relay, start capacitor and overload may need replaced. Have you noticed any change in cooling or freezer temperatures? Sea Breeze
Nov 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cooling
the clicking noise is probably the compressor srart relay opoerating but the compressor not starting. compressor faulty and an expensive repair
Sep 03, 2008 | Maytag MBB1956GES Bottom Freezer...
Refrigerators Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
